RH80-6 not clamping
Posted: Wed 15 Apr , 2026 12:35 pm
by mr_cnc
hi, could anyone tell me what the diagnostic # is for the micro switch (on the FANUC control) that indicates that the turret is clamped on my RH80-6 turret?
thanks Russ
Re: RH80-6 not clamping
Posted: Fri 17 Apr , 2026 11:06 am
by Martin
Diagnostic 0.6 if its a Fanuc OT-A control
Posted: Sun 09 Aug , 2026 15:47 pm
by mr_cnc
Hi all, I'm still having trouble with my Cyclone, I now have four overheat alarms (she's been off for over a month) #1007, 1017, 1021 and 1022. Does anyone know how to reset or what is triggering the alarms?
thanks Russ
Posted: Mon 10 Aug , 2026 8:52 am
by Martin
Not sure where to start.
It would be worth checking that the 24Volts DC is present.
It may be that the memmory has been lost. (there is a battery pack on the side & if the batterys have gone flat & the machine is turned off then the memmory will be reset) You will need to do a restore if this is the case. Do you have a copy of all the parameters & diagnostics?
Posted: Mon 10 Aug , 2026 16:19 pm
by mr_cnc
fixed! it was a 24v problem a short on the turret encoder, where I'd been trying to sort the intermittent turret clamp problems I've been having
