RH80-6 not clamping
hi, could anyone tell me what the diagnostic # is for the micro switch (on the FANUC control) that indicates that the turret is clamped on my RH80-6 turret?
thanks Russ
Re: RH80-6 not clamping
Diagnostic 0.6 if its a Fanuc OT-A control
N8.pdf
(20.18 KiB) Downloaded 60 times
Hi all, I'm still having trouble with my Cyclone, I now have four overheat alarms (she's been off for over a month) #1007, 1017, 1021 and 1022. Does anyone know how to reset or what is triggering the alarms?
thanks Russ
Not sure where to start.
It would be worth checking that the 24Volts DC is present.
It may be that the memmory has been lost. (there is a battery pack on the side & if the batterys have gone flat & the machine is turned off then the memmory will be reset) You will need to do a restore if this is the case. Do you have a copy of all the parameters & diagnostics?
fixed! it was a 24v problem a short on the turret encoder, where I'd been trying to sort the intermittent turret clamp problems I've been having
