Nextmove ST or Denstep Baldor Control Card
To help you dignose which top Baldor control card you currently have:
This is the Denstep top card which used to run with later DOS machines, and earlier Version 2 VR Milling machines.
Only has RS232 connection to maximum of 19200 Baud
This is what we call the DenStep top card with a RED seven segment LED display
This is the newer (current) NextMoveST control card - green seven segment LED.
USB port was added to later versions.
Older software eg, Version 2 milling will have a machine name suffix NS
eg: MicroRouter NS
