DOS Software and Control Boards
DOS software and control boards
Directory Name, Machines supported, Control Manufacture, Control Type
Drivers2 All N/A All
Fanucmd.tri Triac, Novamill Optimised Eurocard
Fanucms Triac Servo Optimised STE Bus
Fanucsld Starturn 5 GSM LCB3
Fanucsmd Starmill Optimised Eurocard
Flstep Novaturn Optimised Smartstep, Eurocard
Flstep Mirac Optimised Smartstep, Eurocard
Flstep Cyclone Optimised Smartstep, Eurocard
Flstep TU150 E Optimised Smartstep, Eurocard
Flstep Microturn Optimised Smartstep, Eurocard
Heiden.sm Starmill Optimised Smartstep, Eurocard Heiden.tri Triac Optimised Eurocard
Mirac Mirac GSM LCB3
TU150 TU150 Servo Optimised STE Bus
TU150E TU150E Optimised Eurocard
I believe this table shows which DOS software to use for which machine :?
EDIT - Table tags not working too well so look at the attached .pdf instead
DOS-Which-Software.pdf
(9.48 KiB) Downloaded 1260 times
Directory Name Machines supported Control Manufacture Control Type
Fanucmd.tri Triac Novamill Optimised Eurocard (3U)
Flstep Novaturn, Mirac, Cyclone, TU150 E, Microturn Optimised Smartstep Eurocard ?
Heiden.sm Starmill Optimised Smartstep Eurocard ?
Heiden.tri Triac Optimised Smartstep Eurocard ?
TU150E TU150E Optimised Eurocard ?
