VMC1300. Spindle motor does not turn. Blown fuse ?
After the spindle was stalled (contact with vice, probably my fault!) the spindle no longer turns (I can hear the relay operate) I suspect the spindle motor fuse. Where is the fuse panel located. How do I access the fuses. Which fuse is the spindle motor. What type of fuse do I need to replace. Is there anything else I need to check. The machine backs against a wall so I want to be ready on Tuesday to move the machine and investigate.
Re: VMC1300. Spindle motor does not turn. Blown fuse ?
Hi Emersok,
Please see this post on the forum regarding the fuses:
viewtopic.php?p=15453&hilit=0850#p15453
Kind Regards
