Mystery Machine Microrouter V3
Hello!
I am brand new to this so please bear with me. I have gotten my hands on what I believe is an older Microrouter V3 model as it's still got its black box.
I couldn't find the data plate around the machine nor around and inside its control box so I have honestly no idea what I have.
I want to use this to learn CNC and make some wood projects. The computer it came with appears to be... a bit busted but I'm hoping to access its harddrive to see whats on it. I managed to get into the control box and it does not look at all standard so I would like to ask the hive mind.
Hopefully it fires up once i get ''new'' hardware :wink:
Thank you!!
IMG_20240420_163102 - Copy.jpg (190.66 KiB) Viewed 18590 times
IMG_20240420_163057 - Copy.jpg (275.63 KiB) Viewed 18590 times
WhatsApp Image 2024-04-22 at 16.31.04_3a06efeb - Copy.jpg (322.24 KiB) Viewed 18590 times
Re: Mystery Machine Microrouter V3
It has had a different spindle motor fitted & also the electronics are not the original that we would have fitted.
I guess somebody on the Forum will be able to identify what make of control it is now.
Hi Martin!
HUH... that's interesting. when I get some time ill investigate the spindle motor. The electronics are a mystery to me. IM going to get a spare PC soon so I can see how it behaves.
Thank you!
