Tether Pully Guide Assembly
This file can be downloaded to produce a pully system to tension the tether guide.
PULLEY BRACKET (9.1.18).stl
(55.55 KiB) Downloaded 1381 times
The STL can be 3D Printed and one of the F1 in school axles can be used as a shaft for the pulley
The pulleys can be purchased through Rapid Electronics
https://www.rapidonline.com/rapid-25mm- ... 10-37-0381
