QuickCAM Pro will not open VR Milling as a normal user
If I am logged the machine as the Administrator and open QuickCam Pro go through the process of producing a file I then get to the last screen which is "Post Proccess" click the button and save the file VR Milling V5 opens but If I perform the same function as a standard user when I click on "Post Proccess" it only saves the file and DOES NOT open VR Milling V5.
Because the normal user will be using a different INI file (settings), it may be that the option to output to VR Milling is not turned on..
Check it on the Options menu (see attached) ..
Turns on or off, the automatic output of cnc files to VR Milling v5
