1967 Viceroy cross slide seems to be a bit missing
Posted: Fri 11 Aug , 2023 9:19 am
by Kimg
Hi I am new to this site and I am looking for information on a viceroy lathe in regards to the cross slide on a 1967 lathe there seems to be a bit missing
between the feed nut and the cross slide the counter bore in the cross slide is about 5/8" dia and about 4mm deep the boss on the nut is half inch diameter by 3/32" deep is there a drawing for this item or a picture so I can make one as I can not see them fitting a 1/2" boss with tolerance of 2 thou in a 5/8" hole and just using the screw to keep it in position Thanks in advance any help welcome
regards
Kimg
Re: 1967 Viceroy cross slide seems to be a bit missing
Posted: Sun 13 Aug , 2023 13:38 pm
by Pete.
The nut should have a 5/8" spigot. Perhaps yours has a compound slide nut fitted or one off another lathe?
Posted: Sun 13 Aug , 2023 17:48 pm
by Kimg
Hi thanks for the replay it from an earlier machine than the feed screw nut you have shown which from 1970 on machine see drawing ml100/512A
again thanks for the replay
regards
kimg
