F1 Fixture Setup
Here is a link to a YouTube Video on the setup and alignment of the F1 Fixture
https://www.youtube.com/watch?v=erTtXYixrEM
Attached are programs for checking the alignment.
JIG SETUP.zip
(4.47 KiB) Downloaded 1599 times
Also attached is a couple of programs that can be used to drill axle holes in the F1 Model Block. The Datum has to be set in the center of the hole in the model block. The program should be run prior to machining the car so that the billet is fixed securely.
The axis hole coordinates have to be entered into the program prior to use.
Drill Axle Holes.zip
(828 Bytes) Downloaded 1515 times
Re: F1 Fixture Setup
I have expanded on this Jig Setup a little with the inclusion of a 4th axis program and a PDF document which outlines the steps required to use the jig setup program. The new jig program also removes less material from the model block, in most cases this leaves the block free to be used for machining a car body from.
F1 Fixture Setup.pdf
(576.9 KiB) Downloaded 1476 times
Jig Setup.zip
(9.69 KiB) Downloaded 1025 times
