Starmill Specs
Struggling to find specifications or travel and spindle taper for what i believe is a 1995 Starmill i'm looking at purchasing.
Any information would be great
Re: Starmill Specs
I've no idea about the travel but the spindle looks like the Coventry Toolholder quick change unit I have on my Triac.
Re: Starmill Specs
Re: Starmill Specs
Regarding the travel have you looked in the Starmill section at the brochure as that gives travel and some details of spindle taper options depending on whether an ATC is fitted or not, looks like your may have an R8 to Coventry Toolholder quick change adaptor fitted.
Re: Starmill Specs
DavidB wrote:Regarding the travel have you looked in the Starmill section at the brochure as that gives travel and some details of spindle taper options depending on whether an ATC is fitted or not, looks like your may have an R8 to Coventry Toolholder quick change adaptor fitted.
I have looked in the brochure but this particular mill doesn't seem to look like the ones in it or hit the other specifications in the manual. The spindle on the machine is a 0.16KW unlike the others. It appears the spec is different for the non ATC model but no full spec.
Re: Starmill Specs
The spindle motor & softwae limits will be the same on both the Starmill & Starmill ATC.
Spindle .2Kw
X 160mm
Y 90mm
Z 115mm
Not sure on the taper but I will have a look around.
