Denford Easiturn Parameters
Hi there,
We recently moved our Denford Easiturn to another site and havent managed to install it since.
The menu has reverted to spanish and when you pick any of the options the power goes off.
Could anyone help us get the parameters as we don't seem to have a copy of them.
Machines details are:- Denford Easiturn
Serial No. ET06029A
Alan
Re: Denford Easiturn Parameters
Hi Alan,
What control & model is fitted? I presume it's a Heidenhein.
Hi Martin,
It has Fagor 8020 controls
This is all I could find.
DOC100516.pdf
(780.63 KiB) Downloaded 1550 times
That's great Martin, Hopefully the engineer has enough info. to get it up and running now.
thanks
Alan
Hi Martin, do you know how to go about entering the parameters?
All we have is the "modos operacion" menu with nine options.
Also is there an internal power supply/memory that needs replaced?
the machine was disconnected for 5 months
Alan
Hi Alan,
I have attached some Fagor manuals which may help.
I can't remember how they were but hopefully the manuals will help you.
Fagor 8020T programming manual.pdf
(8.22 MiB) Downloaded 1943 times
Fagor 8020T Programming Manual Addendum.pdf
(782.44 KiB) Downloaded 1871 times
Fagor 8020T Operating manual.pdf
(3.47 MiB) Downloaded 1940 times
Fagor 8020T Operating Manual Addendum.pdf
(459.86 KiB) Downloaded 1750 times
Hi Martin,
We have managed to input the 5 parameters MP 21,22,23,61,and 63 from the parameter list.
However the engineer says we need to enter 148 parameters as the default ones that appear dont work.
error codes 108,194,099 and 110 appear when trying to run on current parameters.
thanks
alan
Hi Alan,
I can't find anything more on Parameters.
Thanks Martin
Hi!. Someone have the installation and startup manual of Fagor 8020T? I lost the parameters...
Thanks!
