NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
Hello all!! I have been very busy working on several projects. I have started my retrofitting of a NovaTurn. I will be using Yaskawa AC servos 100W. I will post more pictures and video soon. If you want to see some basic videos please go here;
CNC https://www.youtube.com/watch?v=Zg8HZzmHRtQ
Sound Card https://www.youtube.com/watch?v=E1Xj6C5Uq2I
I have demonstrated Ubuntu 10.04, LinuxCNC and Windows 7, 32bit-MACH3 using a MESA 6i25 for closed loop analog servo control and a PCIe x1 parallel port card to breakout board for open loop stepper control.
In a previous post a few years ago, the unit does not have the controller cabinet. I am designing a new unit. It will be very small.
The Gizmosphere is approx 3.96" x 3.96". The iBOB2 is approx 2.5" x 2.56" in size.
To Admin, I would love to demonstrate your software running on this system if possible.
I welcome any comments or thoughts.
I am still interested in locating a tool turret for this lathe if one is available.
Robert Blanton
Start of retrofit.
Start of retrofit.
Yaskawa Servo 2015-03-04 14.28.18a.jpg (250.34 KiB) Viewed 60633 times
Re: NovaTurn Servo retrofit AMD Gizmosphere iBOB2 PCIe x1
The "Schematic Circuit Diagrams for the Novaturn" reference SHEET number 4, for the 42 way connector. Sheet 4 is not part of the circuit diagrams. Is sheet 4 available?
Iron-Man
Just finished the new X axis servo motor plate. I used my converted Sherline Mill with DC servo amplifiers that I built/designed a few years ago. If anyone is interested, please let me know. Most of the initial work is posted on CNCZONE under Iron-Man Servo. I will be powder coating the parts. I have already started the new design for the Z axis servo plate.
I welcome any comments.
Sherline Mill Servo Plate X Axis
Yaskawa Servo Plate X Axis Mill 2015-03-17 20.28.49.jpg (132.5 KiB) Viewed 60588 times
Yaskawa Servo Plate X Axis 2015-03-19 17.45.17.jpg (82.47 KiB) Viewed 60588 times
Completed Z Axis Servo plate. X Axis Servo plate trial fit. The Z Axis did not come out as planned. I may redo it. I will also be retrofitting a Denford Triac Mill with Allen Bradley AC Servos.
Sherline Mill Z Axis Servo Mount
Sherline Z Axis Plate, 03-29-2015web.jpg (426.73 KiB) Viewed 60563 times
Test Fit X Axis Servo Mount
Test Fit X Axis Servo Plate 1, 03-27-2015web.jpg (427.29 KiB) Viewed 60563 times
Z Axis Servo Mount Polished
Z Axis Servo Plate Polished, 03-29-2015web.jpg (229.71 KiB) Viewed 60563 times
Picture of iBOB2. The iBOB2 turns the Gizmosphere 1 into a powerful CNC controller. You can attach Mesa cards, parallel port cards or any PCIe compatible card.
iBOB2 PCIe x1 interface card.
iBOB2 ver 2small.jpg (240.13 KiB) Viewed 60548 times
not much metal left on the inner wall of those slots! I'm sure you have thought about that. Good work!
TDIPower wrote:not much metal left on the inner wall of those slots! I'm sure you have thought about that. Good work!
Thanks for the comments. I am trying to make as little modifications as possible. The piece is 1/4" aluminum and is very strong. When I get the Triac retrofitted, I may redo the parts in steel.
Iron-Man
From This:
Gizmo 1 I-O plate 04-03-2015web.jpg (400.35 KiB) Viewed 60520 times
Gizmo 1 test fit I-O plate 04-03-2015web.jpg (424.14 KiB) Viewed 60520 times
To This:
Gizmo 1 I-O Shield Polished_web.jpg (314.44 KiB) Viewed 60520 times
iBOB2 Gizmo 1 I-O Polished Shield_web.jpg (363.64 KiB) Viewed 60520 times
Gizmo 1 I-O Shield Polished trial fit 2web.jpg (343.97 KiB) Viewed 60520 times
The I/O shield is now ready for powder coating.
Assembly drawing ST6_0700 shows a # 2MT taper inside part # ST5/703, are the dimensions of this part available? In addition, is part ST5/704 a brushing / bearing?
After a little research, just figured out the part is a "Morse Taper Socket Adapter". I will try this model and adjust as needed; https://www.mscdirect.com/product/details/00185041
ST6_0700.pdf
(68.91 KiB) Downloaded 3008 times
Parts powder coated and ready for install. Currently working on the CNC controller.
Gizmo 1 I/O Plate Powder Coated
Gizmo 1 I-O Plate Powder Coated.jpg (327.54 KiB) Viewed 60433 times
Z Servo Plate Powder Coated
Z Servo Plate Powder Coated.jpg (314.22 KiB) Viewed 60433 times
X Servo Plate Powder Coated
X Servo Plate Powder Coated.jpg (325.82 KiB) Viewed 60433 times
This is what I have in mind for the control panel. I hope to build my own tool changer and C axis. The Gizmosphere will eventually be located inside this cabinet. The cabinet was not available when I started initial design work. The DC drive is a 4 quadrant "servo motor" drive.
hardinge control panel.JPG (221.81 KiB) Viewed 60406 times
control panel inside.jpg (412.95 KiB) Viewed 60406 times
control panel cut out.JPG (209.14 KiB) Viewed 60406 times
control cabinet taped layout.JPG (219.39 KiB) Viewed 60406 times
Cleaning up the NovaTurn and bellows. First custom I/O cable completed. Working on the CNC controller and testing servo motors.
Iron-Man
Custom I-O cable
Custom I-O cable
custom I-O cable #1.jpg (495.61 KiB) Viewed 60331 times
bellows 2 repaired
bellows 2 repaired
Bellows 2 repaired.jpg (319.01 KiB) Viewed 60331 times
Bellows 2 before
Bellows 2 before
Bellows 2 before.jpg (337.69 KiB) Viewed 60331 times
Bellows 1 repaired
Bellows 1 repaired
Bellows 1 repaired.jpg (177.45 KiB) Viewed 60331 times
Bellows 1 before
Bellows 1 before
Bellows 1 before.jpg (268.3 KiB) Viewed 60331 times
NovaTurn clean-up
NovaTurn clean-up
Novaturn clean-up.jpg (701.85 KiB) Viewed 60331 times
I have been working on a design based on the iBOB2 and Gizmosphere 1. The Dimensions of the GQ1 are Width 6.79", Height 6.61" and Depth 10.29". It has 6 axis of +- 10V analog servo control and all I/O are available on 2 DB50 and 1 DB 25 connector. The RJ45 is for a pendant interface. It could also be made for step and direction. I prefer true closed loop control. I plan on selling the iBOB2 for anyone who wishes to make a ultra small CNC controller or place the complete controller within a small case or enclosure.
The small circuit board in the back left is the iBOB2.
This will be used for the NovaTurn Lathe.
I need to machine my own chuck key. Can anyone post the specs and a high resolution image of the NovaTurn chuck key?
Iron-Man
Does anyone have the exact part number for the NovaTurn encoder or data sheet?
I should be posting video of the NovaTurn AC soon.
Iron-Man
it's coming on well. nice to see the progress.
TDIPower wrote:it's coming on well. nice to see the progress.
Pete thanks for the comment.
Iron-Man
I have had to repair the encoder, it was faulty / defective. I have posted all the information that I could locate that might identify the encoder.
It appears to be a 755A with a 10mm shaft with flat. In the Novaturn, only A and index are used.
I modified my encoder to provide all signals, A A', B B', Z Z' which will be used for position control.
I had to replace the ET7272B as it was faulty. I may modify the case to accept a 10 pin connector for quick disconnect.
For those of you who might have a damaged or faulty encoder, please see the information below.
I am currently designing a circuit to interface the Hardinge control panel to the MESA 7i77. This circuit will control the leds and membrane switches without using any additional I/O on the 7i77.
Has anyone looked at the Gizmosphere for CNC / control applications?
I hope this helps,
Iron-Man
Encoder housing 1 2015-09-16 20.39.33.jpg (180.4 KiB) Viewed 59897 times
Encoder Housing 2015-09-16 20.37.55.jpg (198.97 KiB) Viewed 59897 times
Encoder Novaturn 2015-10-14 22.05.09.jpg (284.17 KiB) Viewed 59897 times
Encoder Test Set-Up 2015-09-29 21.27.30.jpg (457.01 KiB) Viewed 59897 times
et7272_a1.pdf
(47.85 KiB) Downloaded 4984 times
Encoder 755a-shaft.pdf
(746.18 KiB) Downloaded 3316 times
PathPilot on AMD Gizmosphere1, T40E + iBOB2
I am almost finished. I have PathPilot running on the GizmoSphere 1.
Specs:
G-T40E dual-core processor running at 1.0 GHz, combined on a single die with AMD Radeon™ HD 6250 discrete-class graphics. The board provides a performance capacity of 52 gigaFLOPS (GFLOPS) at less than 10 watts. Custom high- and low-speed edge connectors enable a full range of functions. This unprecedented level of integration between serial and parallel processing offers a power-efficient foundation for high-performance multimedia content delivery across a broad range of embedded designs such as digital signage, x86 set-top box (xSTB), IP-TV, thin client, information kiosk, point-of-sale, casino gaming, media servers and industrial control systems.
Currently decoding I/O on the Hardinge interface. The MPG, Axis select, and Rapid Override are functioning under Linuxcnc. I just need to change the bit file and 7i77 I/O for complete functioning.
Iron-Man
GizmoSphere 1 PathPilot 2015-11-09 20.jpg (381.48 KiB) Viewed 59802 times
Hardinge Test 2015-11-09 small.jpg (450.2 KiB) Viewed 59802 times
Novaturn 2015-11-09 small.jpg (345.68 KiB) Viewed 59802 times
