Viceroy T.D.S 1/1 G.B - Bedway repair
Hello
To repair the damage to the lathe bedway, I glued wet/dry strips onto wood. The strip width and location matched the damaged area so I wouldn't take metal off good parts of the bed.
The chrome bed is very hard and only a small amount of metal was removed. Bearing blue showed a good fit to the saddle with no sign of high spots.
400 grade paper being used to take off any high spots.  1200 grade (back ground) was used to finish.
Dazz
