Mirac "Error 128"
Hello all,
A Mirac without system disk has been donated to our students’ workshop. You can see it below:
We've created a system disk with DOS 5.0 and added files from Drivers.zip and Mirac.zip in it. However, we get same error with this topic: viewtopic.php?f=9&t=3837
Also we've tried all suggestion related with communications issues. We've changed machine's address in mirac.go and macmirac.go to all com1, com2, com3.
You can see configurations of mirac connections below:
Do you have any about idea our mistake? Or content of mirac.go and macmirac.go?
Best regards,
Re: Mirac "Error 128"
Just pulled out the electrical record sheet for this machine which say's, "SOFTWARE UPDATE 20/12/93 V2-16".
The record sheet says it was dispatched with 3.26 so not sure what this refers to.
DOC050413.pdf
(78.49 KiB) Downloaded 1355 times
3.26 is BIOS ver.
In Mirac.zip file at website;
mirac.go
IBM.RS2 2
$3F8 4 COM1
$3E8 4 MACHINE
DENFORD.KBD 1
18.2 $2F8 3
VGA.CRT 0
MIRAC.APP
and macmirac.go
IBM.RS2 1
$3E8 4 COM1
DENFORD.KBD 1
18.2 $2E8 3
EGA.CRT 0
MIRAC.APP
some questions arises at this point:
$3F8 4 COM1 at first file while $3E8 4 COM1 at second file, however it is address of COM3.
also, VGA.CRT 0 at first file while EGA.CRT 0 at second file, I have EGA in xt286 of our Mirac.
finally I have both desktop tutor and qwerty keyboard, but with this files I define here only one.
You may not have seen these posts which should help you decide how to use the files:
Different .GO files for DOS FLSTEP Software
viewtopic.php?f=9&t=740
Desk top tutor software on a different number serial port
viewtopic.php?f=9&t=296
Can I operate my DOS machine software from a QWERTY keyboard
viewtopic.php?f=4&t=59
Denford FANUC Milling and Turning Offline and Desk Top Tutor
viewtopic.php?t=1084
How do I change which COM ports my DOS machine software uses
viewtopic.php?f=4&t=58
Mirac's fixed overlay fanuc desktop tutor works properly. I've double checked all ports and its address on XT 286 with it.
No problem seems on system and Mirac DOS software disk.
Also, I've checked fuses on circuits. However, there is no power at any indicator LED on circuit.
Still has "Error <50> Mirac controller slave disconnected." then "Error <128> Software aborted."
Where should I check next?
Sounds like you need to trace the supply with a voltmeter onto the LCB3 board and look for fuses / diodes / thermals / capacitors which may have tripped or blown.
Electrical schematics are here:
viewtopic.php?t=1384
and here:
viewtopic.php?f=54&t=3452
