Lathe accessories
Found this while looking through some bits I had scanned previously. Posted it as Dazz has made his own and there seemed to be a lot of interest in it.
Edit by Andy B - the post by Dazz is here
Viceroy-copy-and-taper-attachment.pdf
(350.08 KiB) Downloaded 2584 times
Re: Viceroy copy and taper attachment pdf
My taper attachment is a genuine Denford factory original.
I made skates to follow the straight edge. These skates are intended to optimise surface finish.
Dazz
Ah sorry :oops: I thought you'd made one...must have been someone else
Taper turing & Copying attachment
Here are some component drawings for the taper turning and copying attachment.
I'll add more as I find them.
Taper turning and copying.zip
Taper turning & copying attachment drawings
(541.4 KiB) Downloaded 1499 times
Re: Lathe accessories
Excellent!
Richard
Collet Attachment drawings:
Assy - ML107
ML107.PDF
Collet Assy
(53.09 KiB) Downloaded 1284 times
Handwheel - ML107-1
ML107-1.PDF
Handwheel
(85.21 KiB) Downloaded 1217 times
Drawbar - ML107-4A
ML107-4A.PDF
Drawbar
(73 KiB) Downloaded 1180 times
Please don't post comments in this thread - put them in the general threads section.
Boring Table and Milling Attachments
ML118/1 Boring table
ML118-1 Boring Table.pdf
(338.3 KiB) Downloaded 1005 times
ML130/1 Swivel Plate Slide, Milling Attachment
ML130-1.PDF
(103.47 KiB) Downloaded 1053 times
ML130/2 Swivel Tenon Plate, Milling Attachment
ML130-2.PDF
(102.96 KiB) Downloaded 980 times
ML130/3 Swivel Vice, Milling Attachment
ML130-3.PDF
(85.92 KiB) Downloaded 1004 times
ML130/4 Vertical Slide, Milling Attachment
ML130-4.PDF
(149.65 KiB) Downloaded 997 times
ML130/5 Adjusting Screw, Milling Attchment
ML130-5.PDF
(90.12 KiB) Downloaded 995 times
ML132 Universal Milling Attachment
ML132 Universal Milling & Drilling Unit.pdf
(435.42 KiB) Downloaded 975 times
ML132/1 - Boring Table, Universal Milling Attachment
ML132-1.PDF
(141.38 KiB) Downloaded 984 times
ML132/3 - Packing Plate, Universal Milling Attachment
ML132-3.PDF
(130 KiB) Downloaded 952 times
ML132/6 - Angle Plate, Universal Milling Attachment
ML132-6.PDF
(78.92 KiB) Downloaded 953 times
