wanted micromill spares
hi
I am in need of a baldor optimised control board for my micromill 2000 F391 issue 1 (with orange coloured connector blocks).
it must be in full working order.
regards baz
Re: wanted micromill spares
We may have something suitable here.
Can you post a photo of what you need - do you need the top card, bottom or both ?
hi
i am just about to go off on holiday and will be away for 2 weeks, during my 'ordeal' would you please check for the bottom board, balder opt control, f391 iss 1, scj 01 34, scl 2 9u 94vo, sometimes described as the board with 'orange' connectors. i will look out for your reply when i return. thanks baz
I presume you are after a Denstep bottom board.
The following link should help you to identify it.
https://www.denfordata.com/projectimages ... _guide.pdf
board piccie please ignore the baked bean can proping it up (lol)
hi
board now repaired and works great
baz
