Sharpedge TDS 12/16 & TDS 12/10 information
Hopefully all the Sharpedge info you'll ever need.
(with some TDS lathe info mixed in as well)
Denford-Viceroy-Sharpedge-Leaflet.pdf
(303.08 KiB) Downloaded 2290 times
Re: Viceroy TDS and sharpedge A3 arrangement drawings
Would it be possible to add the attachment please. Hopefully the information will be off use in answering my query from yesterday.
Re: Sharpedge information
I'm doing it now but something is struggling to cope somewhere.
Drill Sander sharpedge brochures and parts lists
Sharpedge Grinding Wheel Details
and
Sharpedge TDS 1216 General arrangement
Sharpedge-TDS-1216-General-arrangement.pdf
(152.78 KiB) Downloaded 2514 times
Sharpedge-Grinding-Wheel-Details.pdf
(26.3 KiB) Downloaded 2137 times
TDS 12 and 16 Sharpedge instruction manual
and
Viceroy TDS29 sharpedge Setting Instructions
Viceroy-TDS29-sharpedge-Setting-Instructions.pdf
(181.53 KiB) Downloaded 2195 times
TDS-12-16-Sharpedge.pdf
(487.74 KiB) Downloaded 3643 times
Viceroy-TDS-and-sharpedge-A3-arrangement-drawings.pdf
(785.17 KiB) Downloaded 2593 times
Re: Sharpedge TDS 12/16 & TDS 12/10 information
Sharpedge gearboxes apparently changed several times over the years, and it looks as though the top Oilite bush also changed. These drawings will hopefully help to identify the variations.
The Oilite bushes appear to be standard sizes - such as can be found by this supplier (Usual disclaimer applies)
Edited to replace (hard to read) drawings with Black & White versions
SH_GEARBOX.pdf
Gearbox versions
(41.43 KiB) Downloaded 1549 times
SH5008_OILITE.pdf
Bushes
(25.11 KiB) Downloaded 1684 times
