Starmill Steppers
Can anybody tell me what the stepper motors are in a Starmill. I can only access the X axis one and that has no label or number that I can find. Cheers Phil.
Re: Starmill Steppers
Can you post the serial number & year of manufacture?
Thank you for prompt reply. As far as as I can tell, year of manufacture is probably 1993 or 1994 as I have a price list that came with it dated Jan 1993. As for serial no's, this on the main board- 98712407 Don't know where to find chassis serial, space is limited in my workshop and I have to move machine around to get at all of it. But if I know where to look.
I did find a rather worn label on the X stepper. Partially disernable- Rotalink DF?15 1/5VDCG5(or 9) is this any help? Regards Phil.
The serial plate should be on the side of the black box (electrical cabinet).
The motors are most likely,
Make Model Volts Ac/Dc Phase
x-axis MAE HY200-2220-210-BY08 30 DC
y-axis MAE HY200-2220-210-BY08 30 DC
z-axis MAE HY200-2220-210-BY08 30 DC
I have found the Serial number inside the white control cabinet on the bottom obscured by wires. It is 230288 Possibly preceded by a 4 so (4) 230288 probably 1993 vintage. Regards Phil.
Martin wrote:The serial plate should be on the side of the black box (electrical cabinet).
Can you post some photos?
From a starmill parts list I have:
X Stepper: Cetronic Dynamics HY-200-2220-210-A8
Y Stepper: Cetronic Dynamics HY-200-2220-210-A8
Z Stepper: Cetronic Dynamics HY-200-3424-310-A8
Right, here is the correct information. Disregard all previous woffle. ( Should have worked for ministry of disinformation, or the government) Year of manufacture- 1988 machine serial- 280361. control serial- 230288.
Control- 24v main motor Spindle- .3hp .22KW DC Ph. Thank you again. Phil.
starmill 001.jpg (734.11 KiB) Viewed 11865 times
Starmill front.jpg (672.97 KiB) Viewed 11865 times
Starmill front 2.jpg (665.49 KiB) Viewed 11865 times
