Cyclone machine parameters
Cyclone OT-A & OT-B/OT-C parameters.
CYCLONE.zip
(2.1 KiB) Downloaded 2454 times
CYCLONEA.zip
(1.17 KiB) Downloaded 2186 times
Re: Cyclone machine parameters
Is there any chance the zip files are corrupted? Tried to download and open both files, with different browsers and unzipping software but both seem to be incomplete/corrupted - 0T-A after #0171 and 0T-B&C after #0507.
There is always the chance that I'm missing something entirely..
Have posted again.
CYCLONEA.zip
(1.17 KiB) Downloaded 1573 times
CYCLONE.zip
(2.1 KiB) Downloaded 1532 times
Thank you for updating these Martin.
Are there 900 series parameters for the 0T-A? The file for the 0T-B&C have these.
Thank you!
The 900 parameters are the Fanuc options so were different on each machine as with the 450 diagnostics.
If you let me have the serial number I may be able to locate a copy.
Thank you for this.
The machine serial number is CY22129 G
It is a Jan '90 build with 0T-A control
Are the 450 diagnostics set based on viewtopic.php?f=33&t=2916 ?
Thank you!
Hope this helps.
DOC171018.zip
(254.25 KiB) Downloaded 1776 times
Hi There, I am looking at purchasing a Harrison TU150 P. Serial Number TP0011. Is this an OT A,B or C machine and do you have an original copy of the parameters? Electrics Serial 3061795
It will be a FANUC OTA Control.
Attached is the Electrical Record Sheet for TP0011 although the control serial number is different.
TP0011_1.DOC
(26.5 KiB) Downloaded 1036 times
