Triac PC Electrical Drawings
Does anyone have electrical drawings for a Triac PC manufactured in 2000. I have downloaded a couple from 1999, they are numbered TR6-m01 and TR6-m11 so presume the series runs from TR6-m01 up. Any help would be appreciated.
many thanks
Re: Triac PC Electrical Drawings
I have some more info if it helps!
ser no. H00688/3
elect ser no. OC00222465
I have downloaded some more drawings, but there are 131 pages and several different series of drawings.I am busy trying so suss out the correct ones.
Any help in identifying the correct dwg numbers would be great.
thanks again
This is your original spec sheet if that helps ?
H00688_1.pdf
(35.74 KiB) Downloaded 2068 times
Thanks for that but I was hoping for specific electrical drawings for this machine. It appears that every one is different depending on options fitted etc.
I think I can manage to peice together all the information from the drawings I have and do my own drawings. I have no problems with the machine I just like to have all the information to hand!
thanks
Ok - I thought the spec sheet will at least confirm which drives, motors and options were fitted
