NextMove & Denstep Input /Output Circuit Repair Info
The attached document will detail how to determine which of the 2 control cards is faulty if you have an Input or Output problem and which chips can be replaced to try and resolve the problem.
Also attached is a detailed circuit diagram showing the I/O circuitry.
Nextmove ST and SST IO schematic (4).pdf
(207.86 KiB) Downloaded 2015 times
NextMove Input and Output circuit.pdf
(84.21 KiB) Downloaded 2516 times
