Tailstock Wanted
Hi all
I am looking for a tailstock for a Mirac PC or the drawings or a sample unit to allow me to make one, can anybody help?
Graham
Re: Tailstock Wanted
Is this still an active requirement?
I have made an adaptor that fits a Myford 7 series tailstock to a Mirac PC bed.
I can supply a drawing and photograph if you still need something.
I am still looking for one, that would be great, thanks for the offer.
Graham
Finally I tidied up my drawings for the Myford tailstock adaptor to fit a Mirac PC.
Attached are drawing files and photographs.
You may notice that I fitted some captive brass shims where the tailstock sits on the adaptor this was to finally achieve correct centre alignment. Without this the machining would be much more dificult as I had to measure Mirac centre heights etc. Also this allows for variations that may be present as not all Myford tailstocks may be dimensionally identical (wear and re-scraping/grinding etc.)
Hopefully this will provid eneough info to inspire you to build your own. I can answer specific queries if you have them.
Peter Jackman
End view of adaptor in position with Mirac bed end cover replaced.
General view of adaptor and tailstock fitted.
View showing adaptor in position without Mirac bed end plate in place
UNDER RAIL (MIRAC TAILSTOCK ADAPTOR).pdf
2 off these rails screwed under the channel base simulate the myford bed.
(138.77 KiB) Downloaded 1189 times
MIRAC T.STOCK BED CLAMP.pdf
This clamp locks the channel base to the Mirac bed when slid horizontally to the work position.
(133.72 KiB) Downloaded 1131 times
CHANNEL BASE (MIRAC TAILSTOCK ADAP).pdf
This channel is the main adaptor component.
(217.83 KiB) Downloaded 1296 times
