280VS help sought
Hello all,
I'm hoping someone here may be able to help.
We have a 280Vs lathe which has become slower over time. On investigation of the variable speed mechanism, I get the impression it has been 'got at' in some way. Without any useful drawings, it's difficult to figure out what the problem is.
Does any kind soul have such a machine, who could perhaps take a few photos of the mechanism for me? Even better, are there any detail drawings available of this part of the lathe?
Thanks and Regards,
Arthur G
Which VS version do you have - with the motor in the cabinet and a manual speed control shown here, or with the motor mounted on the back of the headstock, and a pilot motor to change the speed via a joystick on the control panel as shown here?
Is there any obvious belt slip / wear?
My VS is an electric version, for which I have several photos and drawings - but I may have some for the manual version also.
Andy,
that was quick! Thanks for your response.
Ours is a manual version, and I don't think the problem is the belt, as there's no sound of slippage and no rubber dust in the cabinet.
If I could see the area around the thrust bearing on the end of the variable pulley, I think I could figure out what's missing or mucked about with.
Regards,
Arthur G
The assembly drawing for the drive is MVS 100/200 - but I'm not sure it will help you too much, but maybe Admin can scan it for you.
Attached is the equivalent drawing for the Synchro model, along with a picture - I think all the variable speed models used the same pulley set, just mounted in different ways.
I have taken the pullies apart on mine a while ago, but I can't remember exactly how I did it now apart from using a pair of g-clamps to prevent the sprung pulley from flying apart when I undid the retaining bolt/washer.
Hope this helps a bit.
Synchro drive arrangement photo
Synchro drive.jpg (96.17 KiB) Viewed 7255 times
Denford SL100-100.zip
Synchro drive arrangement drg
(1.07 MiB) Downloaded 1027 times
Thanks Andy,
though the setup on the synchro is different than ours, the principle is the same. It gives me confidence to sort ours out. I suspect the thrust bearing seized on ours in the past sometime and that some there was some collateral damage too. I'll send pictures on Monday if I remember to bring my camera to work.
Thanks again for your help and encouragement, and well done to Denford for having such a useful resource available in this forum.
Regards,
Arthur G
