Re: Novaturn Dimensioned Drawings
no probs, it'll take me a while to get it apart.
angel-tech wrote:no probs, it'll take me a while to get it apart.
Thanks, angel-tech.
Iron-Man
all apart, ask away.
I have printed the BOM for the TP121 Turret.
I have highlighted the parts we have in stock in Green. We only have one or two of each of the bits which are for spares use.
I would assume you will be able to locate the electrical parts elswhere but may be interested in the Main Shaft worm shaft and worm gear.
I have also priced thes components.
I will see if I can add the drawings for the toolpost body and tool turret.
turret TP121 parts list.pdf
(55.98 KiB) Downloaded 1438 times
Here is the drawing for the turret assembly, the turret body and the tool plate.
Tp121.pdf
(128.32 KiB) Downloaded 1436 times
Tp121_02.pdf
(171.55 KiB) Downloaded 1520 times
Tp121_01.pdf
(185.25 KiB) Downloaded 6429 times
Steve wrote:Here is the drawing for the turret assembly, the turret body and the tool plate.
Steve
Thanks for all the information :D .
Iron-Man
Iron Man -
Which Harting connector was it in the end please?
I have a Novamill which seems to use the same type but no control box so am going to use Mach 3. I don't want to start rewiring the mill so need to find a connector.
Admin, please could you confirm that the Novamill and Novaturn use the same type?
John.
JohnHaine wrote:Iron Man -
John.
I have not purchased it. I lost some of my research on an older computer and have not recovered it yet. I believe that it is a Han® 42 DD connector. https://www.harting.co.uk/imperia/md/con ... n_d_dd.pdf
See page 13 of the above document. Also, see this file viewtopic.php?f=42&t=2629 document NVT-D11E.pdf.
Hope this helps,
Iron-Man
Great, thanks for your help.
John
