Simulation Datum Position
Is it possible to change the datum position from the Left Front Corner to the Left Rear Corner in the VR Machine, 3D and 2D simulations?
When I run the simulation now, I can see the tool movements in front of the billet, not on it.
The program is being written by hand, not with a CAM package. Customer wants to zero the tool on the back left corner of the part, when looking from the front of the virtual machine. Everything I have ever done has been using the front left corner of the part. Basically, everything I have ever done, runs in the positive x and y. Customer wants to run in the negative y and positive x, if that makes sense to you.
Thanks for the help.
With the simulation Window active there is a Simulation window at the top of the screen.
Select the Datum position option and then select where you want to work from. :D
You can add an offset to allow the datum position to be in the center of the hole of an F1 car for instance. :idea:
dat pos.jpg (17.32 KiB) Viewed 6177 times
