Riser block
I have a Triac PC made in 2002 with easy change tool holders. It is an excellent machine but I find lack of Z height a frequent problem. Has anyone fitted a riser block on one of these machines or could offer advice on fitting a riser block? Is there any diagrams available showing the fixing of the column to the base?
Re: Riser block
hi sir!
i made a riser block last year on mine, i can send you cad drawing of it for free
i don't use my triac so many time, it made just a couple of week since i can run it on mach3
Re: Riser block
I did some years ago, sure I posted it on here. Search my posts.
without measuring, I think it was 50mm I added without having to remake cables, I can't remember how I lifted the column in place but it wasn't difficult.
Re: Riser block
Here is the link to TriacWhizz's post...
viewtopic.php?t=318
Did the machine manage to find the tool carousel height on its own or did you have to tell it the offset?
Edit... Just had a look, obviously the he carousel is attached to the head so no calibration needed.
Re: Riser block
Would anyone happen to have drawings for the riser block?
Re: Riser block
I know this is an old thread, but would anybody still have the drawings for the riser block?
