Triac PC spindle motor speed varies by its self
I have had the Triac PC for at least 10 yrs helping me to build Loco bits and bobs.
The spindle speed is now varying by its self.
I was advised that it may be a capacitor on the spindle control board was going bad .
I replaced all the capacitors on the board ( the round can type ones )
This didnt cure the problem
Does any one have a solution or idea where to go next .
regards Alex
Re: Triac PC spindle motor speed varies by its self
Measure the 0-10V DC analog input to the spindle drive.
It should be 10V at max speed. 5V at half speed. Is this voltage going up and down or stable?
Next measure the DC motor voltage going to the motor is this going up and down?
It could be motor brushes or the motor tachometer
What is the requested spindle speed?
Steve wrote: ↑Thu 20 May , 2021 5:53 am Measure the 0-10V DC analog input to the spindle drive.
Thank for your reply
I have taken the cover off the spindle motor
not sure what wires do
they are marked from top t1 then t2 then k1 then k2 then a1 and the bottom one a2
t1= blue (thin) t2 red (thin) K1 Blue (thin) K2 (thin) a1 blue (thick) a2 Brown (thick)
measured a1 and a2 @250rpm 61-62vdc (varies) then @4000rpm 70-73vdc (varies) seems really high.
as I increase the speed to 4000rpm it doesnt seem like it is going at 4000 rpm seems much slower
and varies. If it was a petrol engine I would say "its hunting " so to speak.
not sure if I have got the correct wires to test but as the a1 and a2 are much thicker thought they may be +and - , just guessing as I dont have a diagram .
any help would be greatly recieved.
Alex
Martin wrote: ↑Thu 20 May , 2021 8:18 am What is the requested spindle speed?
Using the software Vr milling, it varies at all selected speeds with the slider, when in jogging mode.
any help would be great I just dont know where to start , now that I replaced all the metal little round capacitors with the correct values on the spindle controller board.
had a look at the 4 motor brushes and they seem ok as do the 4 tac ones there wasnt any black stuff floating around and everything looks clean, the bearings look good as well.
regards Alex
Can you make the voltage measurements on the spindle drive and report?
You could try adjusting the Stability pot on the Sprint 1200 spindle drive.
Do you know which pair does what, and what the voltage should be ?
denford driver pic1.jpg (596.02 KiB) Viewed 158766 times
denford driver pic2.jpg (563.93 KiB) Viewed 158766 times
denford drive motor.jpg (186.23 KiB) Viewed 158766 times
do you have a diagram to pinpoint the position of the 0-10v dc analog input to the spindle drive. etc, as Im working in the dark on your suggestions, its like , I know that you can get a bus into town, but need to know where the bus stop is located and what number is on the bus , otherwise if I jump on the first bus that comes along, it could take me anywhere lol.
I'm at the passenger level not the bus driver , who knows his route lol
I appreciate your help enormously
Alex
Not sure if this will help but I uploaded the drawings for a sprint controller, may not be the same though viewtopic.php?f=46&t=4778
Please send a larger picture of the spindle drive.
Download electrical diagrams
file:///C:/Users/soddy/Downloads/TriacPC-Electrical-Drawings.pdf
View page 36
Wires 54 and 55 are the analogue
spin drive.JPG (46.2 KiB) Viewed 158761 times
Wires 17 and 19 look like the motor DC
The voltage on those Pins at 250 (slowest speed ) is 4.6 -4.78 DC , fluctuates
the voltage on the pins at 4000 (highest speed ) is 6.7 - 7.32 DC , fluctuates
It doesnt get near to 10vdc on full speed
wonder why that is ?
regards Alex
TDIPower wrote: ↑Fri 21 May , 2021 13:21 pm Not sure if this will help but I uploaded the drawings for a sprint controller, may not be the same though viewtopic.php?f=46&t=4778
Thanks Pete but I dont have the wire/ volt settings to see if they are similar , but will have a look at yours
Many thanks Alex
Steve wrote: ↑Fri 21 May , 2021 13:34 pm Please send a larger picture of the spindle drive.
View page 36
amaxlegend wrote: ↑Fri 21 May , 2021 18:24 pm The voltage on those Pins 54 (-) and 55 (+) at 250 (slowest speed ) is 4.6 -4.78 DC , fluctuates
regards Alex
Can you supply photos of the inside of the electrical cabinet It sounds like the spindle analog card has failed.
Steve wrote: ↑Fri 21 May , 2021 19:10 pm Can you supply photos of the inside of the electrical cabinet It sounds like the spindle analog card has failed.
inside case and board pics for triac
spin drive.JPG (46.17 KiB) Viewed 158753 times
b1 denford.jpg (381.58 KiB) Viewed 158753 times
b2 denford.jpg (973.98 KiB) Viewed 158753 times
b3 denford.jpg (889.01 KiB) Viewed 158753 times
b4 denford.jpg (860.64 KiB) Viewed 158753 times
b5 denford case.jpg (955.53 KiB) Viewed 158753 times
b6 denford case.jpg (809.95 KiB) Viewed 158753 times
b7 denford case.jpg (863.08 KiB) Viewed 158753 times
b8 denford case.jpg (863.08 KiB) Viewed 158753 times
case denford.jpg (977.36 KiB) Viewed 158753 times
triac spindle.jpg (948.41 KiB) Viewed 158753 times
Martin wrote: ↑Fri 21 May , 2021 10:21 am You could try adjusting the Stability pot on the Sprint 1200 spindle drive.
ok will try this over the weekend
regards
Alex
Hi Steve whats the solution . is there a replacement available or can you replace a component ie what needs fixing or replacing
Do you have the wiring diagram for this machine that you can send me.
regards Alex
View page 36
Hi Steve cant realy read this as its a bit blurred any chance you could send me the pdf for the Triac as it would be useful to have. do you have any other documentation on the triac
regards Alex
You should be able to prove if its the sprint by disconnecting the 0-10v from the denford control and just wiring a pot as per the diagram for the sprint I pointed you to. that way you can manually alter the speed and see if it stays stable or hunts. If it is fine then it points to the problem being from the denford 0-10v. At least that way you know where to look.
