Project of the Week: Quick Change Tool Rack
The tool rack project allows you to not only store your tools where they are clearly identified but allows you to refit tools and set the offsets automatically.
The Long series ¼” Ball Nose Cutter is stored as Tool 1 the reference tool and will have a zero offset the other offsets are set in relation to this tool and will have preset values.
Tool offsets.JPG (66.61 KiB) Viewed 18977 times
Using the Quick Change toolholders the tools can be fitted and set to the correct length then secured in position.
The toolrack is designed in QuickCAM 2D Design and the design file can be downloaded here along with a document showing how the CNC program has been created. The Quickcam file has to be downloaded and Unzipped to be used.
Quick CAM 2D Design File:
TOOLING RACK 2020.zip
(32.53 KiB) Downloaded 1081 times
Tool cutter plan:
Quick CAM 2D Design tool rack plans.pdf
(1.09 MiB) Downloaded 1169 times
The final G&M code program is attached below as an FNC file.
This program can be used to cut the toolpath
The Program needs a 6.35mm Slot Drill (Tool 2) and a 3.175mm Slot drill (Tool 3) to be produced and holds the Denford recommended tool set and a photo engraving cutter.
TOOLING RACK 2020.fnc
(40.71 KiB) Downloaded 1043 times
Laser cutting the identification plaques finishes off the project:
laser files2020.zip
(10.19 KiB) Downloaded 1077 times
Re: Project of the Week: Quick Change Tool Rack
The quick change tool holders can be bought individually or as a set including the collet for the router motor.
BI00810DM is the part number for the 1/4" tool holder with a 10mm shank
BI00846SRH is the part number for a set of holders and a collet to suit the standard Kress router motor
BI00846PRH is the part number for a set of holders and collet to suit the PRO router motor
BI00846 is the part number for the recommended router tooling package.
