Re: Triac Z axis counter-balance
sneakym8 wrote:The motor probably just needs new
bearings
Just seen this too! I'll pull it apart and have a look.
On a plus note the Z axis is fine it was just the Jib moving and jamming the z axis. As you say - the head falls down on its own without the gas spring :)
bearings
Had a look tonight - looks like the cap/cover for the encoder got pushed down a bit far and the noise was just the end of the servo shaft catching on the cover.
Hopefully I may get to fire her up over the weekend :)
Thats all good news then .
Looks like it was an easy fix.
Has it still got the Bob Cambell
Break out board fitted ?
sneakym8 wrote:Thats all good news then .
Yes that's still there. It looks exactly the same as it did in the pics you posted in your build thread on here Colin.
I posted some pics I took in that thread yesterday.
Have you had any issues with the spindle making small movements when it is supposed to be idle?
Nope but it has only been powered up for an hour yesterday...
As I say it all seemed to work okay. It doesn't move as fast as it did in your video but I think that maybe set-up with Mach.
Do you happen to have the settings you used in Mach?
I'm also trying to figure out the limit switches - the original ones are all in place (2 per axis) but they don't trip the machine.
There are 3 proximity switches (not sure of the correct term ) the do trip when the metal brackets move over them (y and z only the X is dangling loose). I'm assuming they are to be set as home sensors?
I need to set up some soft limits in Mach as I don't want to damage anything.
Yes they are home switches . The dangling one is definatly not as it was . I will dig around see if i kept the settings . I think it was safely fast traversing at 5m/min
If it had a bit more voltage at the drives it would go a bit faster i think i had a 55v transformer and i think it would go to about 70v , (all this is from memory).there is current limiting resisters on the input of the
Cambell board this is to protect the 8v proximiters fom the 12v coming from the board. The guy that got it from me could not grasp that and thought i had done something really bad wiring the 8v proximiters to 12v so i thought i would explain.
Just thought i would add . The 8v proximiters are original denford and were already fitted.
i think have what you want but can't upload the file here
pm me your email and i will send it
Just PM'd you Colin :)
Just for info as it's been 6 years or so since I was working on this Triac and life got in the way...
Anyway, I never did get it going again but I started to go back over it last week and I'm just refreshing my memory on what is what with this thread and add a little more for future reference.
Jobs done:
- X axis ballscrew has to be shimmed as I found the mounting faces for the nut not 100% parallel?
- X axis ballscrew replaced and preloaded with less than a thou backlash.
- Oiler pipe for the X ballscrew fixed and re-positioned as the oil was tracking down the pipe and not dripping onto the screw (possibly why is
failed in the first place?
- Cleaned the ways.
- Y axis screw preloaded and again less than a thou backlash.
- Oiler tested.
- Oiler wired up to test via a conventional plug. I need to find out if I can wire it into the board somehow so it operates when the spindle is
rotating. Note: is wasn't connected to any power so possibly why the X screw never had any oil?
To do:
- Re-shrink wrap the encoder wire that I ripped out of the Y axis servo... :cry:
- Drill and ream the new Z axis pulley and cut the keyway (when the broach arrives).
- Add the two seperate gas springs vice the one single it has now. I did suspect this was contributing to the judder in Z movement?
- Wire the X limit switches in and the home sensor.
- Test
A few pictures below. The poor thing has had to sit for may years and really deserves to be working and cutting some chips.
Triac Z pullys.jpg (263.76 KiB) Viewed 23130 times
Triax x limits.jpg (225.06 KiB) Viewed 23130 times
Triax - whole machine.jpeg (688.97 KiB) Viewed 23130 times
x limits and home pic.jpg (43.91 KiB) Viewed 23130 times
