Triton Tool Offsets
Customer Question:
Triton with Pneumatic Vise
VR CNC Milling 2.31
I am trying to set up my tool offsets for 2 different tools. My 1st tool is an 1/16" engraver bit and I have run an engraving program perfect. My second operation I would like to perform is a facing operation. I would like to use a 1/2" end mill for this. I have set up a 1/2" end mill in the tooling button as the second tool. I have also set up the z offsets for both tools from the table in the mill with a global offset of 1.5 which is my billet thickness. When I run my facing program and it gets to this line (G43 Z0.25 H02 M7) It says move limits exceeded. I have followed the setting offsets for multiple tools in the VR CMC Milling User's manual. I have also tried the technical articles on your web site, and the forums. None of it helps.
G43 was not fully implemented - I've looked at the code and it was only available for advanced users (something that never made it to final product)
So, I suspect the G43 is the problem - do you really need to alter the tool Z offset from within the CNC program ?
What are you trying to achieve by changing the tools' Z offset ?
What is generating your CNC programs ?
Can you send the program ?
EdgeCAM 10.75
I am using EdgeCAM 10.75 which is used by Project Lead the Way to teach CAM. I am attaching two different codes that I have generated using EdgeCAM the one entitled PLTWengrave1-29-07.fnc works just fine. The one entitled facingnew.fnc stops at G43 Z0.25 H02 M7. What I don't understand is this line is in both codes and one works and one doesn't. I don't know why I am alter the Z offset, this is what EdgeCAM generated. Please help!
I don't think the attachments worked right, so I have copy the PLTWengrave1-29-07.fnc code into this post.
( Machine Tool : Denford Mill
( Part Name : blue wax
( Programmed By : MR. HARRELL
( Date : 01/29/07
( Time : 07:36:19
( Total Machining Time including Toolchange : 1.620 Minutes
G20
[TOOLDEF T00 D0.25
(USER DEFINED)
T0000 M6
G90 G0 X0.2416 Y1.2717
G43 Z0.25 H00 M7
G1 Z-0.002 F10.0 S1100
X0.2394 Y1.2719 Z0.0 F20.0
X0.2416 Y1.2717 Z-0.002
X0.244 Y1.2686
X0.2435 Y1.2664 Z0.0
X0.244 Y1.2686 Z-0.002
G17 G2 X0.2685 Y1.28 R0.1889 F25.0
X0.3001 Y1.2854 R0.0846 F20.0
G1 Y1.2837 Z0.0
Y1.2854 Z-0.002 F10.0
G2 X0.3448 Y1.2733 R0.0797 F20.0
G1 X0.3439 Y1.2719 Z0.0
X0.3448 Y1.2733 Z-0.002 F10.0
G2 X0.3612 Y1.261 R0.0888 F20.0
X0.3731 Y1.2437 R0.0513
G1 X0.3716 Y1.243 Z0.0
X0.3731 Y1.2437 Z-0.002 F10.0
G2 X0.3808 Y1.2163 R0.0686 F20.0
X0.3816 Y1.1888 R0.3726 F25.0
G1 Y1.1608 F20.0
X0.282 Y1.0964
X0.2811 Y1.0978 Z0.0
X0.282 Y1.0964 Z-0.002 F10.0
G2 X0.2399 Y1.0711 R0.3203 F25.0
G1 X0.2382 Y1.0721 Z0.0 F20.0
X0.2399 Y1.0711 Z-0.002 F10.0
Y1.0623 F20.0
X0.2382 Y1.061 Z0.0
X0.2399 Y1.0623 Z-0.002
G2 X0.2807 Y1.0476 R0.304 F25.0
X0.3214 Y1.0233 R0.1933
G1 X0.3204 Y1.0219 Z0.0 F20.0
X0.3214 Y1.0233 Z-0.002 F10.0
G2 X0.3486 Y0.9982 R0.1571 F25.0
X0.3677 Y0.9663 R0.1118 F20.0
G1 X0.3662 Y0.9656 Z0.0
X0.3677 Y0.9663 Z-0.002 F10.0
G2 X0.3787 Y0.9265 R0.1456 F25.0
X0.3816 Y0.8857 R0.3597
G1 X0.3817 Y0.8815 F20.0
X0.3776 Y0.8807
G3 X0.3321 Y0.8681 R0.3571 F15.0
X0.2898 Y0.848 R0.2162
X0.2446 Y0.8144 R0.2373
X0.2071 Y0.7766 R0.8375 F17.4
G1 X0.2127 Y0.7698 F20.0
X0.2124 Y0.7675 Z0.0
X0.2127 Y0.7698 Z-0.002
X0.2049 Y0.7767 Z0.0
X0.2071 Y0.7766 Z-0.002
X0.2127 Y0.7698
G2 X0.2833 Y0.8079 R0.2866 F25.0
G1 X0.2839 Y0.8063 Z0.0 F20.0
X0.2833 Y0.8079 Z-0.002 F10.0
G2 X0.3293 Y0.8204 R0.215 F25.0
X0.3763 Y0.8254 R0.4939
G1 X0.3813 Y0.8257 F20.0
X0.3816 Y0.8254
Y0.6764
X0.38 Y0.6747 Z0.0
X0.3816 Y0.6764 Z-0.002
X0.5068
X0.5084 Y0.6747 Z0.0
X0.5068 Y0.6764 Z-0.002
Y0.8185
X0.5072 Y0.8189
X0.5122 Y0.8185
G2 X0.5781 Y0.807 R0.4293 F25.0
G1 X0.5777 Y0.8053 Z0.0 F20.0
X0.5781 Y0.807 Z-0.002 F10.0
G2 X0.6536 Y0.7827 R0.4989 F25.0
G1 X0.6539 Y0.7807 Z0.0 F20.0
X0.6536 Y0.7827 Z-0.002 F10.0
X0.7631 Y0.8787 F20.0
X0.7648 Y0.878 Z0.0
X0.7631 Y0.8787 Z-0.002 F10.0
Y1.1097 F20.0
G3 X0.7618 Y1.1473 R0.4599 F15.73
X0.7532 Y1.1823 R0.1075 F15.0
X0.738 Y1.2107 R0.0905
X0.7151 Y1.2355 R0.2219
X0.6655 Y1.2777 R0.2871
X0.6125 Y1.3121 R2.2832 F18.96
G1 Y1.3141 Z0.0 F20.0
Y1.3121 Z-0.002 F10.0
X0.5103 Y1.2449 F20.0
X0.5068 Y1.2468
Y1.3131
X0.5084 Y1.3148 Z0.0
X0.5068 Y1.3131 Z-0.002
X0.4996
X0.4979 Y1.3148 Z0.0
X0.4996 Y1.3131 Z-0.002
Y1.2389
X0.4497 Y1.2046
X0.4461 Y1.2064
X0.446 Y1.2114
G3 X0.4432 Y1.2403 R0.1948 F15.0
X0.4341 Y1.2667 R0.086
X0.4189 Y1.2852 R0.0586
X0.3974 Y1.2986 R0.1082
X0.3389 Y1.3131 R0.1106
X0.286 Y1.3022 R0.1184
X0.261 Y1.2877 R0.1347
X0.2416 Y1.2717 R0.2247
G0 Z0.25 F20.0
X0.5168 Y1.1149
G1 Z-0.002 F10.0
X0.5151 Y1.114 Z0.0 F20.0
X0.5168 Y1.1149 Z-0.002 F10.0
G3 X0.5368 Y1.1021 R0.2758 F15.0
X0.5602 Y1.0918 R0.1168
X0.6022 Y1.0851 R0.1118
X0.6427 Y1.0918 R0.1116
X0.6674 Y1.1024 R0.1411
X0.6887 Y1.115 R0.3718
G1 X0.6904 Y1.1141 Z0.0 F20.0
X0.6887 Y1.115 Z-0.002 F10.0
G3 X0.6864 Y1.1383 R0.1756 F15.0
X0.6789 Y1.1628 R0.0975
X0.6643 Y1.1859 R0.0626
X0.6423 Y1.2055 R0.2265
X0.6017 Y1.2344 R0.2704
X0.5601 Y1.2574 R0.9349 F17.64
G1 X0.5599 Y1.2593 Z0.0 F20.0
X0.5601 Y1.2574 Z-0.002 F10.0
X0.5168 Y1.2286 F20.0
X0.5151 Y1.2295 Z0.0
X0.5168 Y1.2286 Z-0.002 F10.0
Y1.1149 F20.0
G0 Z0.25
X0.4895 Y1.2103
G1 Z-0.002 F10.0
X0.4912 Y1.2134 Z0.0 F20.0
X0.4895 Y1.2103 Z-0.002
X0.456 Y1.1883
X0.4543 Y1.1892 Z0.0
X0.456 Y1.1883 Z-0.002 F10.0
Y0.6925 F20.0
X0.4543 Y0.6908 Z0.0
X0.456 Y0.6925 Z-0.002
X0.4895
X0.4912 Y0.6908 Z0.0
X0.4895 Y0.6925 Z-0.002
Y1.2103
G0 Z0.25
X0.3716 Y1.1326
G1 Z-0.002 F10.0
X0.3733 Y1.1358 Z0.0 F20.0
X0.3716 Y1.1326 Z-0.002
X0.3059 Y1.0891
X0.3024 Y1.0888 Z0.0
X0.3059 Y1.0891 Z-0.002
G2 X0.3407 Y1.0692 R0.1977 F25.0
G1 X0.3397 Y1.0678 Z0.0 F20.0
X0.3407 Y1.0692 Z-0.002 F10.0
G2 X0.3716 Y1.0449 R0.2529 F25.0
G1 X0.3733 Y1.0411 Z0.0 F20.0
X0.3716 Y1.0449 Z-0.002
Y1.1326
G0 Z0.25
X0.5168 Y0.9862
G1 Z-0.002 F10.0
X0.5151 Y0.9835 Z0.0 F20.0
X0.5168 Y0.9862 Z-0.002
X0.5339 Y0.9937
G2 X0.5593 Y1.0024 R0.21 F25.0
G1 X0.5598 Y1.0008 Z0.0 F20.0
X0.5593 Y1.0024 Z-0.002 F10.0
G2 X0.6022 Y1.0096 R0.1218 F20.0
G1 Y1.008 Z0.0
Y1.0096 Z-0.002 F10.0
G2 X0.6457 Y1.0036 R0.1423 F25.0
G1 X0.6452 Y1.002 Z0.0 F20.0
X0.6457 Y1.0036 Z-0.002 F10.0
G2 X0.6716 Y0.9943 R0.1818 F25.0
G1 X0.6888 Y0.9863 F20.0
X0.6904 Y0.9836 Z0.0
X0.6888 Y0.9863 Z-0.002
Y1.0841
X0.6904 Y1.0869 Z0.0
X0.6888 Y1.0841 Z-0.002
X0.6713 Y1.0753
G2 X0.6447 Y1.065 R0.1694 F25.0
G1 X0.6442 Y1.0666 Z0.0 F20.0
X0.6447 Y1.065 Z-0.002 F10.0
G2 X0.5985 Y1.0589 R0.1409 F25.0
G1 Y1.0606 Z0.0 F20.0
Y1.0589 Z-0.002 F10.0
G2 X0.5562 Y1.0639 R0.1644 F25.0
X0.5317 Y1.0736 R0.1364
G1 X0.5168 Y1.0816 F20.0
X0.5151 Y1.0845 Z0.0
X0.5168 Y1.0816 Z-0.002
Y0.9862
G0 Z0.25
Y0.8882
G1 Z-0.002 F10.0
X0.5151 Y0.8866 Z0.0 F20.0
X0.5168 Y0.8882 Z-0.002
G2 X0.5965 Y0.8754 R0.4159 F25.0
X0.6888 Y0.841 R0.4781
G1 X0.6904 Y0.8383 Z0.0 F20.0
X0.6888 Y0.841 Z-0.002
Y0.955
X0.6904 Y0.9559 Z0.0
X0.6888 Y0.955 Z-0.002 F10.0
G3 X0.6681 Y0.967 R0.3072 F15.0
X0.6438 Y0.9768 R0.1309
X0.6023 Y0.9835 R0.101
X0.5613 Y0.9768 R0.1136
X0.5373 Y0.9669 R0.1313
X0.5168 Y0.955 R0.32
G1 X0.5151 Y0.9559 Z0.0 F20.0
X0.5168 Y0.955 Z-0.002 F10.0
Y0.8882 F20.0
G0 Z0.25
X1.2549 Y1.3371
G1 Z-0.002 F10.0
X1.2683 Y1.3167 F20.0
X1.267 Y1.3138
X1.262 Y1.3131
G3 X1.2291 Y1.3061 R0.1958 F15.0
X1.2017 Y1.2902 R0.0695
X1.1867 Y1.2684 R0.0475
X1.1825 Y1.2405 R0.083
X1.1862 Y1.1847 R0.4011 F15.25
G2 X1.1943 Y1.0813 R0.9871 F22.9
X1.1683 Y0.9838 R0.1852 F25.0
X1.1508 Y0.9593 R0.1645
X1.131 Y0.9374 R0.6848 F24.47
X1.0743 Y0.8829 R0.8046 F23.68
G1 X1.0673 Y0.8791 Z0.0 F20.0
X1.0743 Y0.8829 Z-0.002
G2 X1.1016 Y0.8897 R0.4277 F25.0
X1.1548 Y0.895 R0.2402
G1 Y0.8933 Z0.0 F20.0
Y0.895 Z-0.002 F10.0
G2 X1.1938 Y0.8926 R0.2786 F25.0
X1.2319 Y0.8834 R0.1856
G1 X1.2313 Y0.8818 Z0.0 F20.0
X1.2319 Y0.8834 Z-0.002 F10.0
G2 X1.2711 Y0.8662 R0.2294 F25.0
X1.3042 Y0.8461 R0.4676
G1 X1.3043 Y0.844 Z0.0 F20.0
X1.3042 Y0.8461 Z-0.002
X1.3416 Y0.8786
X1.36 Y0.859
Y0.8587
X1.258 Y0.7704
X1.2547 Y0.7728
G3 X1.1794 Y0.8146 R0.3196 F15.0
G1 X1.18 Y0.8162 Z0.0 F20.0
X1.1794 Y0.8146 Z-0.002 F10.0
G3 X1.136 Y0.8252 R0.2034 F15.0
X1.0907 Y0.8279 R0.3321
X1.0027 Y0.8167 R0.3321
X0.9479 Y0.7975 R0.3532
X0.8949 Y0.7724 R1.194 F18.1
G1 X0.8914 Y0.7706 F20.0
X0.8775 Y0.7864
X0.8776 Y0.7871
X0.8816 Y0.79
G3 X0.9292 Y0.826 R1.6637 F18.6
X0.9688 Y0.868 R0.194 F15.0
X0.9838 Y0.8932 R0.1417
X0.9894 Y0.92 R0.0596
X0.975 Y0.9588 R0.0558
X0.9599 Y0.9704 R0.0516
X0.942 Y0.9743 R0.0368
X0.9311 Y0.973 R0.0352
X0.9199 Y0.9689 R0.0868
G1 X0.9167 Y0.9675 F20.0
X0.9006 Y0.9842
Y0.9843
X0.9042 Y0.9878
G2 X0.916 Y0.9974 R0.1023
X0.9298 Y1.0045 R0.0571
G1 X0.9304 Y1.0029 Z0.0
X0.9298 Y1.0045 Z-0.002 F10.0
G2 X0.9442 Y1.0096 R0.0478 F20.0
X0.9593 Y1.0107 R0.0746
X0.9689 Y1.0098 R0.0409
G1 X0.9593 Y1.0091 Z0.0
Y1.0107 Z-0.002 F10.0
X0.9689 Y1.0098 F20.0
G2 X0.9777 Y1.0072 R0.0634
G1 X0.9772 Y1.0056 Z0.0
X0.9777 Y1.0072 Z-0.002 F10.0
G2 X0.9909 Y1.0029 R0.1677 F25.0
G1 Y1.008 F20.0
X0.9926 Y1.0004 Z0.0
X0.9909 Y1.0029 Z-0.002
Y1.008
G3 X0.9751 Y1.0458 R0.0502 F15.0
X0.9362 Y1.0626 R0.05
X0.9183 Y1.059 R0.0403
X0.9016 Y1.0487 R0.0804
G1 X0.8989 Y1.0466 F20.0
X0.8777 Y1.0588
X0.8776 Y1.0595
X0.8805 Y1.0635
G2 X0.8933 Y1.0783 R0.0997
X0.9098 Y1.0893 R0.0575
G1 X0.9105 Y1.0878 Z0.0
X0.9098 Y1.0893 Z-0.002 F10.0
G2 X0.9615 Y1.1023 R0.1029 F20.0
G1 Y1.1006 Z0.0
Y1.1023 Z-0.002 F10.0
G2 X0.9737 Y1.1011 R0.0666 F20.0
G1 X0.9813 Y1.0995
X0.9734 Z0.0
X0.9737 Y1.1011 Z-0.002 F10.0
X0.9831 Y1.0973 Z0.0 F20.0
X0.9813 Y1.0995 Z-0.002
G2 X0.9803 Y1.1306 R0.6091 F25.0
X0.9828 Y1.1698 R0.2643
X0.9934 Y1.2079 R0.1495
G1 X0.995 Y1.2073 Z0.0 F20.0
X0.9934 Y1.2079 Z-0.002 F10.0
G2 X1.0129 Y1.2443 R0.1546 F25.0
X1.0267 Y1.2618 R0.3027
G1 X1.0317 Y1.2651 Z0.0 F20.0
X1.0267 Y1.2618 Z-0.002
X1.014 Y1.2585
G2 X0.982 Y1.2549 R0.1284 F25.0
G1 Y1.2565 Z0.0 F20.0
Y1.2549 Z-0.002 F10.0
G2 X0.9501 Y1.2582 R0.137 F25.0
X0.9196 Y1.2665 R0.3705
G3 X0.9064 Y1.2706 R0.1498 F15.0
X0.8937 Y1.2721 R0.0445
X0.8781 Y1.2694 R0.0408
X0.8654 Y1.2608 R0.0333
X0.8571 Y1.2492 R0.0376
X0.8544 Y1.2357 R0.0302
X0.8551 Y1.2292 R0.0239
X0.8573 Y1.2227 R0.041
G1 X0.8593 Y1.2181 F20.0
X0.8589 Y1.2172
X0.8331 Y1.2101
X0.8323 Y1.2106
X0.8316 Y1.2156
G2 X0.8294 Y1.2437 R0.2258 F25.0
X0.8573 Y1.3093 R0.0862 F20.0
G1 X0.8585 Y1.3081 Z0.0
X0.8573 Y1.3093 Z-0.002 F10.0
G2 X0.9271 Y1.337 R0.0946 F20.0
G1 Y1.3354 Z0.0
Y1.337 Z-0.002 F10.0
G2 X0.9561 Y1.3325 R0.0847 F20.0
X0.9826 Y1.3228 R0.731 F24.13
G1 X0.982 Y1.3212 Z0.0 F20.0
X0.9826 Y1.3228 Z-0.002 F10.0
G3 X1.0104 Y1.3142 R0.4542 F15.68
X1.038 Y1.3107 R0.0977 F15.0
X1.0739 Y1.3171 R0.0917
X1.1059 Y1.3359 R0.1197
G1 X1.1097 Y1.3391 F20.0
X1.1098
X1.1274 Y1.3174
Y1.3169
X1.1233 Y1.314
G3 X1.0942 Y1.2903 R0.2961 F15.0
X1.0721 Y1.2619 R0.1118
G1 X1.0706 Y1.2627 Z0.0 F20.0
X1.0721 Y1.2619 Z-0.002 F10.0
G3 X1.0619 Y1.2317 R0.1084 F15.0
X1.0591 Y1.1991 R0.1713
X1.0624 Y1.1345 R0.5689 F16.4
G1 X1.0679 Y1.0871 F20.0
G2 X1.0705 Y1.0391 R0.3967 F25.0
G1 X1.0688 Z0.0 F20.0
X1.0705 Z-0.002 F10.0
G2 X1.0529 Y0.9409 R0.2676 F25.0
X1.0255 Y0.8885 R0.2703
G1 X1.0123 Y0.8696 F20.0
X1.0037 Y0.8607 Z0.0
X1.0123 Y0.8696 Z-0.002
G3 X1.0384 Y0.8923 R0.4736 F15.82
X1.0805 Y0.9463 R0.2211 F15.0
X1.1099 Y1.0595 R0.2041
X1.1052 Y1.1377 R0.5754 F16.43
G2 X1.1007 Y1.2114 R0.8614 F23.39
X1.1126 Y1.2664 R0.119 F20.0
X1.1471 Y1.3086 R0.1138
X1.1935 Y1.3299 R0.1262 F25.0
G1 X1.1939 Y1.3283 Z0.0 F20.0
X1.1935 Y1.3299 Z-0.002 F10.0
G2 X1.2228 Y1.3353 R0.1451 F25.0
X1.2521 Y1.337 R0.6328 F24.92
G1 X1.2549 Y1.3371 F20.0
G0 Z0.25
X1.9273 Y1.3309
G1 Z-0.002 F10.0
X1.9478 Y1.3171 F20.0
X1.9471 Y1.3138
G2 X1.9388 Y1.2833 R0.2834 F25.0
X1.9247 Y1.2545 R0.1188 F20.0
G1 X1.9234 Y1.2555 Z0.0
X1.9247 Y1.2545 Z-0.002 F10.0
G2 X1.8837 Y1.2208 R0.0885 F20.0
G1 X1.8831 Y1.2224 Z0.0
X1.8837 Y1.2208 Z-0.002 F10.0
G2 X1.822 Y1.2091 R0.1367 F25.0
G1 Y1.2108 Z0.0 F20.0
Y1.2091 Z-0.002 F10.0
G2 X1.7835 Y1.2099 R0.7731 F23.86
G1 X1.7818 Y1.2117 Z0.0 F20.0
X1.7835 Y1.2099 Z-0.002
Y0.8534
X1.7818 Y0.8512 Z0.0
X1.7835 Y0.8534 Z-0.002
G3 X1.8229 Y0.8679 R0.3371 F15.0
X1.8636 Y0.8928 R0.1767
X1.8968 Y0.9272 R0.1814
X1.9231 Y0.9682 R0.3755 F15.0
G1 X1.9254 Y0.9724 F20.0
X1.9484 Y0.9615
X1.9469 Y0.9572
G2 X1.9307 Y0.9158 R0.5001 F25.0
X1.9086 Y0.8769 R0.2266
X1.8188 Y0.7998 R0.2356
G1 X1.8181 Y0.8013 Z0.0 F20.0
X1.8188 Y0.7998 Z-0.002 F10.0
G2 X1.757 Y0.7778 R0.2256 F25.0
X1.6917 Y0.7718 R0.3153
G1 Y0.7735 Z0.0 F20.0
Y0.7718 Z-0.002 F10.0
G2 X1.5616 Y0.7986 R0.3114 F25.0
G1 X1.5622 Y0.8001 Z0.0 F20.0
X1.5616 Y0.7986 Z-0.002 F10.0
G2 X1.4959 Y0.8418 R0.196 F25.0
X1.448 Y0.911 R0.2293
G1 X1.4495 Y0.9117 Z0.0 F20.0
X1.448 Y0.911 Z-0.002 F10.0
G2 X1.4292 Y1.0025 R0.1949 F25.0
G1 X1.4309 Z0.0 F20.0
X1.4292 Z-0.002 F10.0
G2 X1.449 Y1.1014 R0.2428 F25.0
G1 X1.4506 Y1.1008 Z0.0 F20.0
X1.449 Y1.1014 Z-0.002 F10.0
G2 X1.5083 Y1.1912 R0.2793 F25.0
G1 X1.5095 Y1.19 Z0.0 F20.0
X1.5083 Y1.1912 Z-0.002 F10.0
G2 X1.5422 Y1.2225 R0.3283 F25.0
X1.5673 Y1.2416 R0.787 F23.78
G1 X1.5721 Y1.2431 Z0.0 F20.0
X1.5673 Y1.2416 Z-0.002
X1.5357 Y1.2432
G3 X1.5086 Y1.241 R0.0883 F15.0
X1.4819 Y1.2322 R0.1628
X1.4565 Y1.2196 R0.1541
X1.4359 Y1.2017 R0.0852
X1.4186 Y1.1742 R0.1118
X1.4068 Y1.1427 R0.3012
G1 X1.4053 Y1.1379 F20.0
X1.4038 Y1.1373
X1.3828 Y1.1497
X1.3836 Y1.1532
G2 X1.3954 Y1.1959 R0.3506 F25.0
X1.4162 Y1.2353 R0.1467
G1 X1.4176 Y1.2343 Z0.0 F20.0
X1.4162 Y1.2353 Z-0.002 F10.0
G2 X1.487 Y1.2962 R0.17 F25.0
G1 X1.4877 Y1.2947 Z0.0 F20.0
X1.487 Y1.2962 Z-0.002 F10.0
G2 X1.5365 Y1.3138 R0.1866 F25.0
X1.5888 Y1.3187 R0.2478
G1 Y1.317 Z0.0 F20.0
Y1.3187 Z-0.002 F10.0
G2 X1.6572 Y1.3135 R0.4202 F25.0
G1 X1.7244 Y1.3025 F20.0
X1.7911 Y1.2916
G3 X1.8576 Y1.2865 R0.4036 F15.27
X1.8766 Y1.2874 R0.1645 F15.0
X1.8928 Y1.2928 R0.0401
X1.9099 Y1.3072 R0.0565
X1.9245 Y1.3268 R0.3886 F15.13
G1 X1.9273 Y1.3309 F20.0
G0 Z0.25
X1.6193 Y1.2371
G1 Z-0.002 F10.0
X1.621 Y1.2386 Z0.0 F20.0
X1.6193 Y1.2371 Z-0.002
X1.6061 Y1.2385
X1.6056 Y1.2403 Z0.0
X1.6061 Y1.2385 Z-0.002 F10.0
G3 X1.5682 Y1.2015 R0.4171 F15.39
X1.5371 Y1.1568 R0.215 F15.0
X1.5066 Y1.0423 R0.2287
X1.5849 Y0.8818 R0.1983
G1 X1.585 Y0.8796 Z0.0 F20.0
X1.5849 Y0.8818 Z-0.002
G3 X1.6003 Y0.8956 R0.5288 F16.18
X1.6128 Y0.9141 R0.0498 F15.0
X1.6193 Y0.9391 R0.0516
G1 Y0.968 F20.0
Y1.2371
G0 Z0.25
X1.7566 Y1.2141
G1 Z-0.002 F10.0
X1.7583 Y1.2156 Z0.0 F20.0
X1.7566 Y1.2141 Z-0.002
G2 X1.7048 Y1.2226 R0.9081 F23.19
G1 X1.7031 Y1.2247 Z0.0 F20.0
X1.7048 Y1.2226 Z-0.002
Y1.0101
X1.7052 Y0.9853
G2 X1.7008 Y0.9595 R0.0673
G1 X1.6992 Y0.96 Z0.0
X1.7008 Y0.9595 Z-0.002 F10.0
G2 X1.6942 Y0.9454 R0.0499 F20.0
X1.6852 Y0.9336 R0.1431 F25.0
X1.6456 Y0.8959 R0.3219
G1 X1.6095 Y0.8672 F20.0
X1.6064 Y0.8669 Z0.0
X1.6095 Y0.8672 Z-0.002
X1.6264 Y0.8594
G3 X1.6506 Y0.8502 R0.2146 F15.0
G1 X1.6501 Y0.8485 Z0.0 F20.0
X1.6506 Y0.8502 Z-0.002 F10.0
G3 X1.7133 Y0.8426 R0.263 F15.0
X1.7369 Y0.8439 R0.193
G1 X1.7566 Y0.8464 F20.0
X1.7583 Y0.8449 Z0.0
X1.7566 Y0.8464 Z-0.002
Y1.2141
G0 Z0.25
X2.4298 Y1.2192
G1 Z-0.002 F10.0
X2.429 Y1.2166 Z0.0 F20.0
X2.4298 Y1.2192 Z-0.002
X2.6074 Y1.3389
X2.6102 Y1.3349
G2 X2.6446 Y1.2808 R0.7642 F23.91
X2.6716 Y1.2225 R0.3606 F25.0
G1 X2.67 Y1.2219 Z0.0 F20.0
X2.6716 Y1.2225 Z-0.002 F10.0
G2 X2.6902 Y1.1259 R0.2684 F25.0
X2.6738 Y1.0358 R0.2408
X2.6008 Y0.9121 R0.4313
G1 X2.5995 Y0.9131 Z0.0 F20.0
X2.6008 Y0.9121 Z-0.002 F10.0
G2 X2.5351 Y0.8399 R0.843 F23.48
X2.4641 Y0.7731 R2.5001 F21.05
G1 X2.4604 Y0.7698 F20.0
X2.46
X2.4568 Y0.7737
G3 X2.4409 Y0.7902 R0.1216 F15.0
X2.422 Y0.802 R0.0748
X2.4045 Y0.8086 R0.0894
X2.3864 Y0.8107 R0.063
X2.3617 Y0.8087 R0.1263
X2.3373 Y0.8028 R0.2
X2.3014 Y0.7892 R0.2763
X2.2663 Y0.7724 R1.2272 F18.15
G1 X2.2628 Y0.7706 F20.0
X2.2603 Y0.7736
G3 X2.246 Y0.7883 R0.1604 F15.0
X2.2297 Y0.7987 R0.0575
X2.2071 Y0.8064 R0.0786
X2.1828 Y0.8085 R0.1283
X2.1316 Y0.8006 R0.1523
X2.1018 Y0.7883 R0.2029
X2.0729 Y0.7725 R0.5912 F16.51
G1 X2.0699 Y0.7708 F20.0
X2.0536 Y0.7837
X2.0558 Y0.7874
G3 X2.0975 Y0.8726 R0.6247 F16.67
G1 X2.0991 Y0.872 Z0.0 F20.0
X2.0975 Y0.8726 Z-0.002 F10.0
G3 X2.1093 Y0.9097 R0.3219 F15.0
X2.1137 Y0.9475 R0.1461
X2.1089 Y0.9773 R0.0836
X2.093 Y1.0024 R0.0667
X2.0734 Y1.0191 R0.0691
X2.0499 Y1.0249 R0.0446
X2.0357 Y1.0218 R0.0301
X2.0223 Y1.0132 R0.069
G1 X2.0192 Y1.0107 F20.0
X2.0027 Y1.0236
X2.0043 Y1.0272
G2 X2.0313 Y1.0603 R0.082
X2.0718 Y1.0726 R0.0659
G1 Y1.0709 Z0.0
Y1.0726 Z-0.002 F10.0
G2 X2.0881 Y1.0704 R0.0489 F20.0
X2.1027 Y1.064 R0.0759
G1 X2.1019 Y1.0625 Z0.0
X2.1027 Y1.064 Z-0.002 F10.0
G2 X2.119 Y1.0546 R0.0955 F20.0
G1 X2.1248 Y1.0502
X2.1266 Y1.0465 Z0.0
X2.1248 Y1.0502 Z-0.002
G3 X2.1163 Y1.1434 R0.7292 F17.07
X2.0811 Y1.239 R0.2591 F15.0
X2.0616 Y1.2631 R0.0998
X2.0363 Y1.2721 R0.0352
X2.0252 Y1.2698 R0.021
X2.0159 Y1.2621 R0.0281
X2.0061 Y1.2437 R0.0372
X2.0021 Y1.22 R0.3315
G1 X2.0014 Y1.2151 F20.0
X2.0011 Y1.2148
X1.9784 Y1.2191
X1.9786 Y1.2234
G2 X1.9839 Y1.2664 R0.2297 F25.0
X2.0022 Y1.3061 R0.1031 F20.0
G1 X2.0036 Y1.3051 Z0.0
X2.0022 Y1.3061 Z-0.002 F10.0
G2 X2.0649 Y1.337 R0.0745 F20.0
G1 Y1.3354 Z0.0
G2 X2.1027 Y1.3286 R0.0795 F20.0
X2.1344 Y1.3069 R0.1458 F25.0
G1 X2.1333 Y1.3056 Z0.0 F20.0
X2.1344 Y1.3069 Z-0.002 F10.0
G2 X2.1693 Y1.2642 R0.1264 F25.0
X2.1877 Y1.2195 R0.3309
G1 X2.1868 Y1.2168 Z0.0 F20.0
X2.1877 Y1.2195 Z-0.002
X2.3633 Y1.3388
X2.3661 Y1.3351
G2 X2.4037 Y1.2766 R0.348 F25.0
X2.4298 Y1.2192 R0.6957 F24.38
G0 Z0.25 F20.0
X2.1952 Y1.1926
G1 Z-0.002 F10.0
X2.1933 Y1.1933 Z0.0 F20.0
X2.1952 Y1.1926 Z-0.002
G2 X2.207 Y1.1255 R0.3279 F25.0
G1 X2.2054 Y1.1245 Z0.0 F20.0
X2.207 Y1.1255 Z-0.002 F10.0
G3 X2.2256 Y1.1152 R0.3255 F15.0
X2.2472 Y1.1065 R0.1287
G1 X2.2467 Y1.1049 Z0.0 F20.0
X2.2472 Y1.1065 Z-0.002 F10.0
G3 X2.2845 Y1.1023 R0.1172 F15.0
X2.3221 Y1.1065 R0.1495
G1 X2.3225 Y1.1049 Z0.0 F20.0
X2.3221 Y1.1065 Z-0.002 F10.0
G3 X2.3446 Y1.1154 R0.1612 F15.0
X2.3636 Y1.1252 R0.4851 F15.9
G1 X2.3655 Y1.1243 Z0.0 F20.0
X2.3636 Y1.1252 Z-0.002
G3 X2.344 Y1.1974 R0.4448 F15.61
X2.3269 Y1.2354 R0.2684 F15.0
X2.3083 Y1.2675 R0.766 F17.19
G1 X2.3088 Y1.2698 Z0.0 F20.0
X2.3083 Y1.2675 Z-0.002
X2.1952 Y1.1926
G0 Z0.25
X2.4392 Y1.1959
G1 Z-0.002 F10.0
X2.4373 Y1.1966 Z0.0 F20.0
X2.4392 Y1.1959 Z-0.002
G2 X2.4463 Y1.1692 R0.2231 F25.0
X2.4519 Y1.1246 R0.6847 F24.47
G1 X2.4503 Y1.1235 Z0.0 F20.0
X2.4519 Y1.1246 Z-0.002 F10.0
G3 X2.4699 Y1.1155 R0.4424 F15.59
X2.4905 Y1.108 R0.1169 F15.0
G1 X2.4901 Y1.1064 Z0.0 F20.0
X2.4905 Y1.108 Z-0.002 F10.0
G3 X2.5259 Y1.1045 R0.144 F15.0
X2.5613 Y1.1091 R0.1225
X2.5823 Y1.1161 R0.1222
X2.5997 Y1.1243 R0.3429
G1 X2.6015 Y1.1234 Z0.0 F20.0
X2.5997 Y1.1243 Z-0.002
G3 X2.5864 Y1.184 R0.2609 F15.0
X2.5485 Y1.2686 R0.4031 F15.27
G1 X2.549 Y1.2709 Z0.0 F20.0
X2.5485 Y1.2686 Z-0.002
X2.4392 Y1.1959
G0 Z0.25
X2.3648 Y1.0984
G1 Z-0.002 F10.0
X2.3663 Y1.1011 Z0.0 F20.0
X2.3648 Y1.0984 Z-0.002
X2.348 Y1.0899
G2 X2.3224 Y1.0811 R0.123
G1 X2.322 Y1.0827 Z0.0
X2.3224 Y1.0811 Z-0.002 F10.0
G2 X2.2824 Y1.0762 R0.1368 F25.0
G1 Y1.0778 Z0.0 F20.0
Y1.0762 Z-0.002 F10.0
G2 X2.2419 Y1.0811 R0.1504 F25.0
X2.2083 Y1.0935 R0.1961
G1 Y1.0914 F20.0
X2.2066 Z0.0
X2.2083 Z-0.002 F10.0
X2.2066 Y1.0962 Z0.0 F20.0
X2.2083 Y1.0935 Z-0.002
Y1.0914
G2 X2.2031 Y1.0371 R0.2544 F25.0
X2.1919 Y0.9946 R0.4095
G1 X2.1893 Y0.9919 Z0.0 F20.0
X2.1919 Y0.9946 Z-0.002
G2 X2.2226 Y1.0036 R0.3465 F25.0
G1 X2.223 Y1.002 Z0.0 F20.0
X2.2226 Y1.0036 Z-0.002 F10.0
G2 X2.2401 Y1.0073 R0.1862 F25.0
X2.2582 Y1.0085 R0.105 F20.0
G1 Y1.0069 Z0.0
Y1.0085 Z-0.002 F10.0
G2 X2.3045 Y1.0013 R0.1358 F25.0
G1 X2.3039 Y0.9997 Z0.0 F20.0
X2.3045 Y1.0013 Z-0.002 F10.0
G2 X2.3302 Y0.9908 R0.1882 F25.0
X2.3491 Y0.9809 R0.4476
G1 X2.3501 Y0.9784 Z0.0 F20.0
X2.3491 Y0.9809 Z-0.002
G3 X2.3653 Y1.0834 R0.3635 F15.0
X2.3648 Y1.0984 R0.2113
G0 Z0.25 F20.0
X2.601 Y1.0935
G1 Z-0.002 F10.0
X2.6024 Y1.0959 Z0.0 F20.0
X2.601 Y1.0935 Z-0.002
X2.5847 Y1.0873
G2 X2.5612 Y1.081 R0.1472 F25.0
X2.5248 Y1.0784 R0.1898
G1 Y1.0798 Z-0.0002 F20.0
Y1.0799 Z-0.0001
Y1.0796 Z-0.0005 F10.0
Y1.0797 Z-0.0004 F20.0
Y1.0794 Z-0.0007 F10.0
Y1.0795 Z-0.0006 F20.0
Y1.0792 Z-0.001 F10.0
Y1.0793 Z-0.0009 F20.0
Y1.079 Z-0.0012 F10.0
Y1.0791 Z-0.0011 F20.0
Y1.0788 Z-0.0015 F10.0
Y1.0789 Z-0.0014 F20.0
Y1.0786 Z-0.0017 F10.0
Y1.0787 Z-0.0016 F20.0
Y1.0784 Z-0.002 F10.0
Y1.0785 Z-0.0019 F20.0
Y1.0786 Z-0.0017 F20.0
Y1.0788 Z-0.0015
Y1.079 Z-0.0012
Y1.0792 Z-0.001
Y1.0794 Z-0.0007
Y1.0796 Z-0.0005
Y1.0798 Z-0.0002
G2 X2.4861 Y1.0821 R0.1793 F25.0
X2.453 Y1.0928 R0.1668
G1 X2.4514 Y1.0954 Z0.0 F20.0
X2.453 Y1.0928 Z-0.002
G2 X2.4515 Y1.0723 R0.4047 F25.0
X2.4462 Y1.0444 R0.1529
G1 X2.4446 Y1.0448 Z0.0 F20.0
X2.4462 Y1.0444 Z-0.002 F10.0
G2 X2.4377 Y1.0154 R0.2014 F25.0
G1 X2.4305 Y0.997 F20.0
X2.4276 Y0.9946 Z0.0
X2.4305 Y0.997 Z-0.002
G2 X2.4529 Y1.0015 R0.2699 F25.0
G1 X2.4532 Y0.9998 Z0.0 F20.0
X2.4529 Y1.0015 Z-0.002 F10.0
G2 X2.4837 Y1.0049 R0.1507 F25.0
G1 X2.4838 Y1.0032 Z0.0 F20.0
X2.4837 Y1.0049 Z-0.002 F10.0
G2 X2.5095 Y1.0033 R0.1568 F25.0
X2.5345 Y0.9966 R0.1108 F20.0
G1 X2.534 Y0.995 Z0.0
X2.5345 Y0.9966 Z-0.002 F10.0
G2 X2.5594 Y0.9867 R0.1381 F25.0
X2.5773 Y0.9766 R0.2447
G1 X2.5781 Y0.9741 Z0.0 F20.0
X2.5773 Y0.9766 Z-0.002
G3 X2.594 Y1.0299 R0.5257 F16.16
X2.6011 Y1.0903 R0.2295 F15.0
G1 X2.601 Y1.0935 F20.0
G0 Z0.25
X2.5665 Y0.9494
G1 Z-0.002 F10.0
X2.5686 Y0.9498 Z0.0 F20.0
X2.5665 Y0.9494 Z-0.002
G3 X2.549 Y0.9613 R0.1956 F15.0
X2.5264 Y0.9714 R0.0995
X2.5057 Y0.9776 R0.0824
X2.4838 Y0.9791 R0.1191
X2.4505 Y0.9745 R0.1077
X2.4152 Y0.9641 R0.1485
G1 X2.414 Y0.9654 Z0.0 F20.0
X2.4152 Y0.9641 Z-0.002 F10.0
G2 X2.3709 Y0.8971 R0.5236 F25.0
X2.3171 Y0.8365 R1.0471 F22.71
G1 X2.309 Y0.8307 Z0.0 F20.0
X2.3171 Y0.8365 Z-0.002
X2.3359 Y0.8455
G2 X2.3849 Y0.864 R0.3436 F25.0
G1 X2.3854 Y0.8624 Z0.0 F20.0
X2.3849 Y0.864 Z-0.002 F10.0
G2 X2.4563 Y0.8756 R0.2316 F25.0
G1 Y0.8739 Z0.0 F20.0
Y0.8756 Z-0.002 F10.0
G2 X2.4866 Y0.8721 R0.1172 F20.0
X2.5119 Y0.8641 R0.2314 F25.0
G1 X2.5124 Y0.8621 Z0.0 F20.0
X2.5119 Y0.8641 Z-0.002
G3 X2.5665 Y0.9494 R0.4747 F15.83
G0 Z0.25 F20.0
X2.3389 Y0.9523
G1 Z-0.002 F10.0
X2.341 Y0.9529 Z0.0 F20.0
X2.3389 Y0.9523 Z-0.002
G3 X2.3209 Y0.9644 R0.5548 F16.32
X2.2988 Y0.9758 R0.1293 F15.0
X2.2807 Y0.9811 R0.0741
X2.2615 Y0.9824 R0.1071
X2.2422 Y0.9808 R0.0903
X2.223 Y0.9756 R0.1436
X2.1798 Y0.9597 R0.1917
G1 X2.1785 Y0.9609 Z0.0 F20.0
X2.1798 Y0.9597 Z-0.002 F10.0
G2 X2.1458 Y0.8855 R0.9257 F23.12
X2.1117 Y0.8288 R0.6441 F24.82
G1 X2.1065 Y0.8242 Z0.0 F20.0
X2.1117 Y0.8288 Z-0.002
G2 X2.1383 Y0.8421 R1.0055 F22.84
X2.1857 Y0.8607 R0.3467 F25.0
X2.2593 Y0.8723 R0.2444
X2.2958 Y0.8692 R0.1894
G1 X2.2966 Y0.8673 Z0.0 F20.0
X2.2958 Y0.8692 Z-0.002
G3 X2.3389 Y0.9523 R0.4396 F15.57
G0 Z0.25 F20.0
M30
facingnew.fnc
Facingnew.fnc code
( Programmed By : MARK
( Date : 01/25/07
( Time : 13:03:03
( Total Machining Time including Toolchange : .175 Minutes
G20
[TOOLDEF T00 D0.5
(FACE MILL OPERATION)
(USER DEFINED)
T0000 M6
S5000 M3
G90 G0 X8.05 Y2.0667
G43 Z0.25 H00 M7
Z0.15 F550.04
G1 Z-0.05 F244.46
X3.05 F550.04
X-0.05
G17 G3 X-0.1125 Y2.0042 R0.0625
G1 Y1.8958
G3 X-0.05 Y1.8333 R0.0625
G1 X3.05
G2 X3.1125 Y1.7708 R0.0625
G1 Y1.6625
G2 X3.05 Y1.6 R0.0625
G1 X-0.05
G3 X-0.1125 Y1.5375 R0.0625
G1 Y1.4292
G3 X-0.05 Y1.3667 R0.0625
G1 X3.05
G2 X3.1125 Y1.3042 R0.0625
G1 Y1.1958
G2 X3.05 Y1.1333 R0.0625
G1 X-0.05
G3 X-0.1125 Y1.0708 R0.0625
G1 Y0.9625
G3 X-0.05 Y0.9 R0.0625
G1 X3.05
G2 X3.1125 Y0.8375 R0.0625
G1 Y0.7292
G2 X3.05 Y0.6667 R0.0625
G1 X-0.05
G3 X-0.1125 Y0.6042 R0.0625
G1 Y0.4958
G3 X-0.05 Y0.4333 R0.0625
G1 X3.05
G2 X3.1125 Y0.3708 R0.0625
G1 Y0.2625
G2 X3.05 Y0.2 R0.0625
G1 X-0.05
X-5.05
G0 Z0.25
M30
It seems like the G43 is causing some random problems as its not a supported G code - happens in VR Milling 5 as well.
I think your best bet is to alter the Edgecam postprocessor to get rid of the G43 command - I can't see why it would be necessary. You may need to contact them on how to do this.
I believe this (attached below) is the Denford post we supply with the F1 In Schools edgecam - might be worth a try -
Denford.mcp
(81.48 KiB) Downloaded 1451 times
That worked perfectly, that Denford post I mean, but is there any way to switch it to english for the units instead of metric??
I haven't used EdgeCAM before, so I can't help much.
Have a google for "EdgeCAM Code Wizard" seems like its some kind of easy post-processor configuration wizard.
I would have thought that you could load up the denford.mcp file somewhere in EdgeCAM, and change some settings (eg, what units to output)
another question
Why when I get to this line of code G17 G2 X12.311 Y17.759 R2.224 does virtual machine say radius: bad arc end point?
I'd need to know the previous X and Y move positions in order to see what the problem is.
Bad arc end point normally occurs because the post processor has rounded up some numbers and rounded down others.
The result is that an arc cannot be created accurately from the given start point (previous XY position), end point(G2/3 position) and radius (R).
I'm pretty sure that the later versions of VR Milling are more forgiving over arc checks, whereas version 2 milling will generate an error even if the arc end point is out by 1 micron (4 tenths")
code
Thanks for your help so far, I really appreciate it!
There is the code up to that line. Is there a quick fix for the post processor to mend this problem?
(EDGECAM CNC OUTPUT - F1 IN SCHOOLS.MCP)
(01/30/07)
(Denford Micro Router)
(MARK)
G21
[TOOLDEF T00 D6.35
[EDGEMOVE X0 Y0
G91 G28 X0 Y0 Z0
M06 T00 (USER DEFINED)
G43 H00
S1100 M3
G1 X9.181 Y35.746 Z5.0 F508.0
Z-0.187 F254.0
Y17.799 F508.0
X11.859
X12.767 Y17.514 R0.867
X13.035 Y17.197 R1.08
X13.144 Y16.758 R0.865
X13.039 Y16.314 R0.915
X12.754 Y15.973 R1.046
X12.283 Y15.777 R0.932
X11.859 Y15.754 R3.303
If you have worked out how to alter the post processor in EdgeCAM, then I would try changing it to:
1. Output arcs using relative centre points (eg, I J values) rather than just radius. eg, G17 G2 X10 Y12.5 I-2 J-3
2. See if you can change any settings to do with minimum arc size - from what I can see from your program, the post has created a tiny arc which is very nearly a straght line.
If you can make these changes, then you could also set it back to imperial units
