Squeeking on the z axis
Hello
After a few years light use our school vertical router has suddenly started making a worrying noise. Jogging on the z axis there is an almighty squeeking.
Perhaps there is some oiling required but it is beyond my knowledge. I have never seen any documentation about maintenance.
I have some course work waiting to be cut but await your response.
Phil
Re: Squeeking on the z axis
Upon further investigation I see the accordion gaiter below has come lose. It appears some dust has gotten into the z-axis thread which is causing the problem.
My proposed course of action:
1) Blow out as much dust as possible with air.
2) Lubricate
3) clip back into position the gaiter
Does that sound like a reasonable approach? Do I need to lubricate and if so with what?
Phil
Hi Phil
Take a look at page 30 of the user manual as attached.
Vertical Router Operator Manual.pdf
(684.59 KiB) Downloaded 3665 times
Hello Martin
Thanks very much for that.
Phil
We are back up running after some overdue maintenance. Now I see we have a broken part that needs replacing.
The most forward metal plate clip that holds the accordion gaiter has bent. The actual accordion seems intact but ruffled.
Can I purchase a replacement plate or gaiter (whichever is easiest) from Denford? I cannot see it on the web site.
Return to “MicroRouter Vertical / MaxiRouter”
