Denford F1 Fixture Parts Description
Denford F1 Fixture Parts Description..
F1 Fixture Parts (Large).jpg (77.86 KiB) Viewed 25249 times
Re: Denford F1 Fixture Parts Description
The part numbers shown here are for a qty of 1 of each item.
If you need the NR1/0426 then you need to order 2 of these.
With the introduction of the F1 Model Block made of foam the bore of the billet was reduced to 18mm.
As a result the spiggot is now a smailler dimension
revised fixture parts.jpg (101.52 KiB) Viewed 14876 times
