RS232 wire end
Hi All,
Just bought an old Starmill the cable from the computer 25 pin (good)has a broken
other end which was round and has 4 wires red, black, white ,yellow.
the machine has a RS232 sticker next to it.
can you help with what I do and where I find one
Gerry
Re: RS232 wire end
What control type is fitted?
Re: RS232 wire end
Hi Martin,
It is original with the machine out of its book :1989 serial no. R.M. 19098A1
serial for the electronics 44.
Re: RS232 wire end
Can you post a picture of the machine & also the electrical panel?
Re: RS232 wire end
Re: RS232 wire end
The manual for the NEE SMCU Starmill shows the pin outs for the RS232 port.
viewtopic.php?f=54&t=3272
Re: RS232 wire end
Hi Martin,
Can't find the pinouts in the download
am I missing something?
Gerry
Re: RS232 wire end
Starmill RS232 Cable.
Re: RS232 wire end
Hi Again,
Am I reading your drg. wrong.
I have 4 wires red, black, white ,yellow. which come from
the rs232.
I can only see red and blue on your drg
could you put me right in laymans terms.
Sorry if i'm a pain
Gerry
Re: RS232 wire end
All the NEE drawings I can see just have the two wires.
Can you look at the other side of the 7 way socket in the electrical box & check if it has 2 or 4 wires.
Re: RS232 wire end
Re: RS232 wire end
It looks as though the internal lead is only 2 + a earth (Shield) so you should be able to check the 25 way D type end & compare it to the drawing above & cut out the other 2 wires.
Re: RS232 wire end
Thanks for your help Martin,
I have finely made a correct 25 /7 (i hope) wire with
your drg.
My next step is to try it.
I bought the Starmill off an old CNC guy(he died 3 yrs ago) his grandson does'nt want to know it.
so I am hoping to breath life back into it.
gerry
