Model Engineer Workshop : Cross slide copier
The No. 202 May 2013 edition of Model Engineer Workshop magazine includes an article on a copier attachment for a Denford Viceroy lathe (but easily adaptible to any other lathe).
If you already have a Denford copy/taper attachment, this is an easy accessory to make and adds useful capability.
If you don’t have the Denford copy/taper attachment, it would be straight forward to reproduce both attachments.
If the lathe looks familiar, it’s probably because you have seen it on this forum.
Re: Model Engineer Workshop : Cross slide copier
Attached are some photos that show a cross slide copier attachment. This is designed to copy the profile of a template onto the end of a bar. This is something that cannot be done with the factory copy attachment. I have used parts of the factory copier to make the cross slide version, but nothing that could not be reproduced in the home work shop.
Shows how the bar that holds the template is fastened to the lathe.
Photo 5 template bar.jpg (348.45 KiB) Viewed 25042 times
The top slide rotated away to show a template in place.
Photo 9.jpg (357.08 KiB) Viewed 25042 times
A template is bolted to a drilled flat bar and the roller follower controls the tool path.
Photo 10 stylus following the template.jpg (281.43 KiB) Viewed 25042 times
The pieces that replace the screw and add a roller follower.
An overview of the end profile copy attachment.
