Which MicroMill 2000 Wiring Diagrams?
I cannot find a set of wiring diagrams that match the MicroMill 2000 I have.
Would someone point me in the right direction......
Thanks in advance,
Orin
Here are photos of the data plate, electronics panel, and close-ups of the 5 relays and controller.
Speed controller appears to be a KB Electronics.
MicroMill 2000 Controller
MicroMill Controller.jpg (140.67 KiB) Viewed 11026 times
MicroMill Data Plate
MicroMill Relays, Terminals, and Fuses
Electronics Panel
Electronics Panel
"It is well that war is so terrible -- lest we should grow too fond of it." Gen. R.E. Lee CSA
Re: Which MicroMill 2000 Wiring Diagrams?
Are the attached drawings the ones I should use for my MicroMill 2000?
It appears that collectively they would be correct for my machine.
These drawings are from file MicroTurn-Electrical-Denstep-110v-circa2000.pdf which I found at:
viewtopic.php?f=36&t=2929
Based on other Denford drawing sets numbering sequence I've looked at, the drawings missing are MK2-1, MK2-2, and MK2-4
and drawings MT-2000-1, MT-2000-2, and MT-2000-4 could be used to replace the missing drawings.
Orin
MT-2000-4.pdf
(12.31 KiB) Downloaded 1121 times
MT-2000-02.pdf
(13.13 KiB) Downloaded 1156 times
MT-2000-01.pdf
(16.33 KiB) Downloaded 1075 times
M2K-AU-3E.pdf
(24.55 KiB) Downloaded 1127 times
M2K-5.pdf
(350.3 KiB) Downloaded 1100 times
Use the Micromill 2000 Denstep drawings from the attached link:
Steve wrote:Use the Micromill 2000 Denstep drawings from the attached link:
Please take a look at the photos of the electronics panel in my MicroMill 2000.
Note that there are 5 relays, not 3 as in the drawings you recommended and that the spindle speed is controlled from the DenStep and not from the front panel mounted pot.
Sorry but I can't find any drawings which match your machine...it could be a development or test machine which would have been documented in the USA office (now closed)
I've added all I could find to this post:
Thank you very much for posting the drawings.
The drawing series M2K-AU xx in file Micromill-2000-denstep-110v-1.pdf appears at first glance to be correct for my machine.
Orin
