Microrouter V5 Electrical Drawings
Hi all,
is there a chance you could post up some electrical drawings that cover my Microrouter Pro V5 NS, serial no H04706 April 04
Graham
Re: Microrouter V5 Electrical Drawings
I Hope these are the correct drawings
Microrouter V5 Pro NS.rar
(325.41 KiB) Downloaded 1509 times
Thanks for the drawings, unfortunately these are not the ones for my machine, here is a photo of the control, as you can see from the pictures my set up has an external Parker XLT50-S stepper driver and an additional PSU.
Is there a chance you still have the drawings for this version.
Graham
Have had a look and cannot find the drawing for your machine.
Do you have a problem with it? I can probably help with that.
The machine was redesigned in 2006 and i attach the schematic for that.
This drawing will show the stepper motor drives you have on the PRO but the relays are now on a PCB.
I attach the diagram for the Microrouter Compact This has the relay arrangement as you machine with the Delay timer and the spindle control relays.
Compact 2003-2005.zip
(184.55 KiB) Downloaded 1332 times
MICROROUTER PRO V5 NS.pdf
(136.53 KiB) Downloaded 1505 times
Thanks Steve,
I don't have a problem, I was trying to work out if I could connect a 4th axis via another external drive.
Graham
Have a look here:
viewtopic.php?f=54&t=3576
Step3 and Dir3 are the 4th axes
Thanks for the tip.
Graham
