TDS 23 Pillar Drill pulleys and motor spec
Ive just got myself a new toy a viceroy tds/23 pillar drillits in exellent condition apart from its missing its motor and drive pulley
So what im asking is has anybody got information on where to get hold of a 4 step pulley with 3 4 5 6 inch steps??
and also need to know the motor spec as I never saw it what hp and rpm possibly spindle height too????
Thanks in advance
Gary :D
Re: tds/ 23
Moved this into the Viceroy section.
I had a look at some of our old drawing scans but can't find anything relevant for you, only this...
SK648-4speed-drill-wiring-diagram.pdf
SK648 4 speed drill wiring diagram .pdf
(138.21 KiB) Downloaded 976 times
Re: tds/ 23
cheers for looking
do you think it should have 2 stepped pullets or one stepped and one with 4 same size wheels
just been looking at other makes some are using 2 different pulleys
my viceroy lathe uses 2 identical wheels
Gary
Re: tds/ 23
Found the drawing for the motor pulley - will try to get it scanned next week.
The diameters are slightly different to the spindle pulley.
The motor spec should be in the parts lists - which I thought were on here somewhere.
Re: tds/ 23
Cheers Andy
That would be much appreciated
The motor was a 3/4 hp 1400rpm 3 phase got a guy on flebay to check his for me
im planning using it in my home workshop so going for a single phase motor I want to modify it to take a 3hp 4 pole still 1400rpm for more torque
any thoughts on this?? things I haven't considered??
Gary :D
Re: tds/ 23
wilson294 wrote:modify it to take a 3hp 4 pole still 1400rpm for more torque
3hp sounds way over the top to me - if you're wanting to use large drills (i.e. bigger than about 3/4") you'll need to decrease the speed anyway. Even if usinga 3phase motor via an inverter, 2hp should be more than enough for this size of machine.
Anyhow, pulley drawings attached.
I think PD3-21 and PD3-22 are right for your drill - PD3-5 and PD3-12 being for the older model.
PD3-22.pdf
PD3-22
(388.49 KiB) Downloaded 1005 times
PD3-21.pdf
PD3-21
(393.12 KiB) Downloaded 979 times
PD3-12.pdf
PD3-12
(534.93 KiB) Downloaded 904 times
PD3-5.pdf
PD3-5
(426.7 KiB) Downloaded 1092 times
Re: tds/ 23
That was brilliant thank you for uploading those drawings where do you come by such things??
I found a pulley on ebay of those dimensions so dont have to get one made happy days :D
an old guy round the corner gave me a single phase motor of 1 hp 1400 rpm that fits nicely
I wired it all up last night had to doctor the three phase switch to work on 1 phase I rewired the light its all nice and neat
thanks to your help it should be turning a drill bit early next week
Thanks again
Gary
Re: tds/ 23
wilson294 wrote: where do you come by such things??
By getting to know the right people :wink:
Glad you're getting it going - please post a picture or two when its done.
We haven't got many postings on the pedestal drills and it does make it easier to answer queries when we can see what we're talking about.
Re: tds/ 23
Sure thing Ill get some pics uploaded by the weekend cant do it just now some tool of a digger driver ploghed down my home phone line today :ReallyMad: had to go out to get the internet
Re: TDS 23 Pillar Drill pulleys and motor spec
Some pics as requested sorry it took so long :D
the drill is an awesome machine unstoppable
Did Denford own Sagar at one point just I have found pics of my old Sagar saw if you want them too??
Gary
