lathe missing shaft and gears what parts do i need
missing gearbox shaft and gears
the lathe resprayed the doors hammered enamel
viceroy lathe 004 (Medium).jpg (71.31 KiB) Viewed 5944 times
no gears
no gears
viceroy lathe 002 (Medium).jpg (84.63 KiB) Viewed 5944 times
missing shaft
missing shaft
viceroy lathe 001 (Medium).jpg (79.44 KiB) Viewed 5944 times
Re: lathe missing shaft and gears what parts do i need
I think you may have a bit of a problem.
As far as I can see you have a slightly different version of the gearbox shown in the scans.
The bits you need look to be shown on section E-E.
There are item drawings available as Pdf's (look for the ML115 section),
but as to how to make or get any of these items,
I think that could be a bit difficult.
Good luck anyway.
Cheers,
Les.T.
PS if anyone can stitch the drawings together that might be helpful
The other Half of ML 115/900
Half of ML 115/900
Half of ML 115/900
I've stitched the drawing together and added some more I think are relevant to this thread:
viewtopic.php?f=50&t=2986&p=11420#p11420
