'NAN' shown axes display / Invalid floating point number
VR Milling 'NAN' shown in real machines axes display
or you get an error message:
xxx.xx is not a valid floating point value
Solution:
This has been seen in the field in France on PCs running French Windows 2000.
The problem is due to the decimal seperator in regional setting being set to a comma
To fix the problem, change setting...
Control Panel -> Regional Settings -> Number -> Decimal Symbol
From a comma ',' to a point '.'
On my version of XP (SP3) you get to it slightly differently:
start > Control Panel > Regional and Language Options > Customise > Decimal Symbol
This problem also effects some of our other software
Re: 'NAN' shown axes display / Invalid floating point number
This has also caused problems with the material library in QuickCAM 2D.
See picture for regional settings screens from Control Panel.
